car feels like its choking - Mustang Evolution
Old 09-22-2013, 09:55 PM   #1
PiojoA7x's Avatar
Recently when step on the gas my car feels like its chocking. It won't accelerate normally. I recently installed an CAI from AM. Maybe that's what making it not accelerate properly. I have a 2003 manual transmission.
PiojoA7x is offline   Reply With Quote
Old 09-22-2013, 10:04 PM   #2
kickerofdoom's Avatar
Check to see if any air leaks
---------- Post added at 10:04 PM ---------- Previous post was at 10:04 PM ----------
Also do u have a tuner or did u reset the car
Old 09-22-2013, 10:32 PM   #3
PiojoA7x's Avatar
I'll check for leaks and I do not have a tuner nor did I reset my car. How do I reset my car. Do I disconnect the battery?
Old 09-22-2013, 10:46 PM   #4
1slosix's Avatar
did you damage the MAF when you took it from the stock air box, or when you installed it in the CAI? i've done that before on a different vehicle is why i ask.
carving corners like a boss
Old 09-22-2013, 10:49 PM   #5
PiojoA7x's Avatar
I was thinking about that. I could of possibly damaged it. Is there a way to fix that or do I have to get another one?
Old 09-22-2013, 10:53 PM   #6
1slosix's Avatar
pretty much if it's broke you'll be buying a new one. check to make sure it's installed right first though. try unplugging it all together...that'll force your car into a minimum crawl mode. see if it still chokes like crazy
Old 09-22-2013, 11:04 PM   #7
PiojoA7x's Avatar
So by unplugging it all together do you mean from the throttle body and take it out completely?
Old 09-22-2013, 11:10 PM   #8
1slosix's Avatar
no thats the IAC...the MAF is what was inside the old air box. see the black box on the tube...see if it's installed right...if so unplug it and try turning the car over.
Old 09-22-2013, 11:22 PM   #9
Unplug the battery to let the car relearn the air.
Old 10-09-2013, 08:15 PM   #10
PiojoA7x's Avatar
So today as I was about to take apart the CAI to see if installed something wrong, I noticed that there is sort of a plug in the pipe that is connected between the throttle and the MAF sensor. It looks like something should be inserted in there but there is nothing in my car that should go there. It's a little black rubber plug. I see other mustangs that have connect a cable in there. I don't have that cable. I think I need something to plug that black rubber hole. I think that's what's making my car not accelerate properly because there's a gap. I have the SR CAI from AM for a 2002 v6 mustang.
Old 10-09-2013, 09:22 PM   #11
bkh1994's Avatar
Just get a plug/cork at an auto parts store or do what I did and use a butt connector thing to plug it lol. I think its the newer cars that don't have anything that fills that spot
bkh1994 is offline   Reply With Quote
Old 10-09-2013, 11:33 PM   #12
sam62893's Avatar
The hole is for the temperature sensor. I have used electrical tape and a big nut to screw in there. You can also go all the way and weld it shut
Old 10-10-2013, 06:03 AM   #13
PiojoA7x's Avatar
Do you guys think that's what making my car choke when I accelerate?
Old 10-10-2013, 06:12 AM   #14
bkh1994's Avatar
It's not helping even if its not the problem haha
Old 10-10-2013, 11:55 AM   #15
BamaStang93's Avatar
That very well could be your problem right there. Or like 1slosix said, it's your MAF. Take some of these guy's advice and just close it up. It definitely couldn't hurt.
BamaStang93 is offline   Reply With Quote
Old 10-11-2013, 11:47 AM   #16
davidcseifert's Avatar
Region: Arkansas
Yeah 01-04 have built in iat in the maf
That's a big vacuum leak after the maf it's hurting something..
blower/new cam soon
07:43 PM
