AM sr intake and tune - Mustang Evolution
Old 09-23-2013, 11:47 AM   #1
I searched the threads on this and found nothing regarding it. Has anyone did the intake and tune set up, just wanted to know was it worth the money for the gains get or response
Old 09-23-2013, 12:02 PM   #2
sam62893's Avatar
Eh. It's just for looks
Old 09-23-2013, 12:45 PM   #3
samuelsmith's Avatar
People will argue that a intake is just a intake and they all get the same results. SR has some of the best results. AM does not post hp/tq results from v-6 intakes.
Old 09-23-2013, 01:09 PM   #4
sam62893's Avatar
An intake without a professional data logged tune is just a piece of pipe with a filter made to look good. No significant gains. Now if you have a dyno of a stock air box and a CIA, I'll believe it
---------- Post added at 02:09 PM ---------- Previous post was at 02:05 PM ----------
Here you go http://youtu.be/gCi2yo4UqPI
Old 09-23-2013, 03:24 PM   #5
Here you go Cold Air Intakes Mythbusted - YouTube
The Mustang v-6 has a pretty good air intake system. A better filter is usually all you need. I like CIAs.
Nothing surprised me from this video. Note, in the beginning he said the factory intake gets cold air.
They used a short air intake and it does not get denser(cold) air when it is trapped in the engine bay. Putting a box around it and restricting air flow will not help. Most people who put boxes around intakes have a sufficient external source of air. If not, they are stupid and so is the manufacture. There are small gains if done properly. If the CAI would have been put through the fender well with cold air from wind the 1.7 gain would be there. Just like the umbilical CAI. Most market horsepower is gained from perfect conditions and more mods. Most companies expect you to know that more mods were done to the vehicle besides a cold air intake.
More air in +more air out + more fuel =more hp
Gravity is in space. A very small amount, but it is there . Could you fool the average person about gravity in space?
. I add this because of the companies disclaimer.
Old 09-23-2013, 06:37 PM   #6
austinknoll's Avatar
Just pull off the silencers and put a k&n filter in. Much less hassle than the sr one. It doesn't fit as good as the oem airbox.
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 09-23-2013, 09:51 PM   #7
1slosix's Avatar
same here....why waste money on a CAI...hell a pvc tube would work just as well for 1/3 the price
carving corners like a boss
Old 09-24-2013, 01:38 AM   #8
My friend put PVC piping in his air intake and it started to melt. I would never do that
65 Mustang coupe
Old 09-24-2013, 01:43 AM   #9
Venomouz831's Avatar
Just get a tuner, and save the cai money on gas
)02 Gt, Founder of WE2G
Old 09-24-2013, 02:41 AM   #10
Ok so the tuner is the most important product than, I already run 93 anyway so I will deft get the tune... thanx for the input guys
Old 09-24-2013, 09:52 AM   #11
1slosix's Avatar
i've never once seen that happen but i guess accidents happen. we even used pvc on a friends mammoth intake on his cobra with no issue. also did your friend leave the pvc as is or did he paint it with engine enamel? we always coat them with that stuff because it not only looks better but protects upwards of 600 degrees.
Old 09-25-2013, 12:51 PM   #12
He's an idiot and painted it with normal spray paint. The intake on his escort has way too many bends for him to use all the PVC he did
65 Mustang coupe
Old 09-25-2013, 08:29 PM   #13
1slosix's Avatar
Wow I agree your friend was not thinking straight lol.
04:57 PM
