cutting springs - Mustang Evolution
Old 09-23-2013, 05:22 PM   #1
TheHulk99's Avatar
cutting springs
if I want to get a 1.5" drop all the way around how much should I cut my springs?
TheHulk99 is offline   Reply With Quote
Old 09-23-2013, 05:26 PM   #2
Venomouz831's Avatar
Do 1 full coil
)02 Gt, Founder of WE2G
Old 09-23-2013, 05:29 PM   #3
TheHulk99's Avatar
Originally Posted by Venomouz831 View Post
Do 1 full coil
with stock springs that will give me a 1.5" drop?
Old 09-23-2013, 05:31 PM   #4
NewMtang's Avatar
Cut off 3 inches. Divided by two and you will get the 1.5 inches you want.
Old 09-23-2013, 05:31 PM   #5
TheHulk99's Avatar
and also what do I need to get to use a cut off wheel? a dremel? or a die-grinder?
Old 09-23-2013, 05:39 PM   #6
TheHulk99's Avatar
what about the rear springs? I thought if they had that pigtail at the bottom you shouldn't cut them because it won't fit correctly when cut?
Old 09-23-2013, 05:48 PM   #7
bkh1994's Avatar
Originally Posted by TheHulk99 View Post
what about the rear springs? I thought if they had that pigtail at the top you shouldn't cut them because it won't fit correctly when cut?
Cut off the bottom
bkh1994 is offline   Reply With Quote
Old 09-23-2013, 06:02 PM   #8
Screaming Mach's Avatar
This is what my Mach looks like after I cut 1 coil off
Screaming Mach is offline   Reply With Quote
Old 09-23-2013, 06:14 PM   #9
TheHulk99's Avatar
looks good, how much did you cut off the back? do you have a pic or the rear?
Old 09-23-2013, 06:38 PM   #10
Thanks I did not cut the back yet I'm putting on DRs and I don't know how much room I will have yet sorry
---------- Post added at 07:38 PM ---------- Previous post was at 07:37 PM ----------
I just could not stand the gap in the front any more lol
Old 09-23-2013, 09:48 PM   #11
1slosix's Avatar
here's my last two cars cut 1.25 coils off the front and 1 coil off the back no isolators.
carving corners like a boss
Old 09-23-2013, 10:15 PM   #12
TheHulk99's Avatar
---------- Post added at 08:15 PM ---------- Previous post was at 08:13 PM ----------
they look good, I think ill do the same cuts. but for the rear springs I am still confused. I'm not supposed to cut the pigtail end right? but if I cut the from the top will it still fit correctly when I put it back on? because I noticed the last coil had a slight bend to it so that it sits almost level.
Old 09-23-2013, 10:17 PM   #13
1slosix's Avatar
when you pull the spring you'll see which end needs to be cut...it can only sit in there one way. honestly it's been 3 years since i cut a set so i don't recall. however i do remember when you look at it that you can only cut it one way to go back in.
Old 09-23-2013, 10:19 PM   #14
TheHulk99's Avatar
okay thanks. I have an extra set of v6 springs I'm going to cut and if I have time ill out them on my car and post pics
Old 09-29-2013, 02:27 AM   #15
TheHulk99's Avatar
so this is how it turned out, I kept the top isolators on in the front and kept the bottom isolators on in the rear. I love the new look. By Tuesday I should have my GT rims on.
Old 09-29-2013, 08:05 AM   #16
SpeedyG's Avatar
Nice ! What sizes did you cut?
SpeedyG is offline   Reply With Quote
Old 09-29-2013, 01:32 PM   #17
TheHulk99's Avatar
I cut 1.25 coils in the front and 1 coil off the back
Old 09-30-2013, 11:10 AM   #18
SpeedyG's Avatar
I'm doing mine now.
Old 09-30-2013, 12:13 PM   #19
TheHulk99's Avatar
I'm doing mine now.
nice! post pics when your done!
Old 10-11-2013, 11:50 PM   #20
Mike V.'s Avatar
What size rims and tires are those Hulk?
Mike V. is offline   Reply With Quote
Old 10-14-2013, 02:35 AM   #21
TheHulk99's Avatar
in that pic those are my old rims. they were 18's and 245's all the way around
Old 10-14-2013, 01:26 PM   #22
mummert_96v6's Avatar
what wheels did you get now?
mummert_96v6 is offline   Reply With Quote
Old 10-14-2013, 03:55 PM   #23
TheHulk99's Avatar
gt rims off my brothers 03
Old 10-14-2013, 04:33 PM   #24
are they the bullits?
Old 10-14-2013, 07:59 PM   #25
TheHulk99's Avatar
no they aren't
Old 10-15-2013, 11:52 AM   #26
andregayola's Avatar
I'm doing mine now.
The ones I gave you ? I wanna see the ed results
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 10-15-2013, 11:45 PM   #27
I hear about people cutting right on the car lol is this possible or is it worth it to pull them out cut it then replace
Joshlowet is offline   Reply With Quote
Old 10-15-2013, 11:48 PM   #28
1slosix's Avatar
pull them out
Old 10-16-2013, 10:10 AM   #29
That my freind is a good way to loose a hand
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 10-16-2013, 10:14 AM   #30
Or your face when it pops out
Old 10-16-2013, 10:16 AM   #31
Or your eyes from the explosion
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 10-16-2013, 11:12 AM   #32
I ment obviously jack the car up first lol
Old 10-16-2013, 01:07 PM   #33
Still no mater how high you jack it up there will still be tension in the springs and when snapped that force is going to do damage and its jut not smart it's easier and safer to remove them and then cut them trust me my friend last thing you want is for you or your car getting hurt
And like always remember
Work smarter not harder
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 10-16-2013, 05:52 PM   #34
sam62893's Avatar
If you cut the spring off in the car still you'll have catastrophic consequences. Just imagine cutting the tension of the spring. It'll shoot randomly even though it's not fully compressed
Old 10-16-2013, 10:50 PM   #35
Yea like i said don't do it ever
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
04:29 PM
