Tuners? - Mustang Evolution
Old 09-25-2013, 09:46 AM   #1
Kbarrett138's Avatar
Tuners?
I've seen a lot about tuners but I still don't know if it's worth it. I don't want to start paying for premium gas either. So is there a tuner out there that is worth the money and give you a noticeable gain without having to change your gas to premium?
Kbarrett138 is offline   Reply With Quote
Old 09-25-2013, 09:50 AM   #2
MidnightBlueGT's Avatar
The street and performance you can remain on 87 octane, race you have to change to at least 91. It is worth it if you have a few bolt ons or even stock because you get free tunes for life with bama and you can check/clear codes with the handheld. You dont notice the $ difference its just a few dollars and with the street tune you should pick up some mpg (i picked up 4) which will compensate it. Just dont keep changing octanes regularly
Old 09-25-2013, 10:25 AM   #3
bkh1994's Avatar
Originally Posted by MidnightBlueGT View Post
The street and performance you can remain on 87 octane, race you have to change to at least 91. It is worth it if you have a few bolt ons or even stock because you get free tunes for life with bama and you can check/clear codes with the handheld. You dont notice the $ difference its just a few dollars and with the street tune you should pick up some mpg (i picked up 4) which will compensate it. Just dont keep changing octaves regularly
+1
bkh1994 is offline   Reply With Quote
Old 09-25-2013, 10:49 AM   #4
samuelsmith's Avatar
Well any sort of professional tuning done to you're car will significantly improve ride quality/drive ability. From increasedresponse to improved gas mileage. Depends on what you hint you're tuner that you want (hey I want increased gas mileage) He will tune the car accordingly.
03:04 AM
