I need some help - Mustang Evolution
Old 09-27-2013, 03:53 PM   #1
Dpred03's Avatar
I need some help
OK so I was driving for a while (2 hours) and when I stopped to fill up I noticed what seems to be a belt chirping. I popped the hood and it seems to be the main belt, I also noticed some fluid coming out of a hose that goes in the back of the alternator. How bad is it if I drive with a slightly chirping belt and does anyone have any idea what that fluid is?
Dpred03 is offline   Reply With Quote
Old 09-27-2013, 03:56 PM   #2
Venomouz831's Avatar
Maybe coolant? I'm trying to think the hose behind the alternator on the v6. As far as the chirping is it the belt or a pulley? Whatever you do don't spray any conditioner on there it will make things worse. But I recommend changing the belt and if the noise is still there then narrow down the pulley
)02 Gt, Founder of WE2G
Old 09-27-2013, 04:03 PM   #3
Dpred03's Avatar
I can't tell the engine is hot still so no clue on the fluid.. If it is coolant how big a deal is it? And how bad is it to drive with it now with the chirp? I am really tight on money right now so if it can wait a few weeks that would be preferable.. How do I tell which pulley needs to be replaced?
Old 09-27-2013, 04:06 PM   #4
alex_ander01's Avatar
If you are leaking coolant, hope its from the reserved portion. If it is, most likely it had a tad to much to begin with and its just doing its job. The chirping noise, its not a big deal. Hopefully tho it is just the belt and not the tension pulley. But I agree, do not spray anything on the belt. It does and will make it worst. Best of luck .
alex_ander01 is offline   Reply With Quote
Old 09-27-2013, 04:07 PM   #5
What color is the fluid? Is it leaking a lot or a little? If it's coolant make sure you never run low or engine will overheat. Get it fixed though whatever it is. Don't worry about the chirp that much I had a chirp from my idler pulley for about 2 weeks. Well that's for you to narrow it down or go to an auto parts store and ask for their help.
Old 09-27-2013, 04:30 PM   #6
Dpred03's Avatar
I'm guessing it clear I can't tell though and I'll get that checked out
10:42 AM
