Plz help! - Mustang Evolution
Old 10-02-2013, 03:33 PM   #1
Blondiebabi1's Avatar
Plz help!
Ultimate question for all you mustang lovers out there. I've got a 98 mustang automatic. I just put a brand new radiator in it and it just had an exhaust repair. Every time it becomes hot outside she doesn't want to **** about 30 it feels almost stuck. It eventfully shifts but then it'll drop speeds and not wanna go. Eventually dropping all the way to zero. It also shakes. This only happens when it's above 65 degrees outside. I've tried just about everything.. If anyone has any idea plz help me
Blondiebabi1 is offline   Reply With Quote
Old 10-02-2013, 04:19 PM   #2
kickerofdoom's Avatar
Check for leaks and also make sure the fan works.
Old 10-02-2013, 04:31 PM   #3
Fan does work I'm positive and their was one leak but it's been fixed
Old 10-02-2013, 05:10 PM   #4
doesn't want to what... re read your post hahah something is blocked **** ...
Mustangman705 is offline   Reply With Quote
Old 10-02-2013, 06:05 PM   #5
maldog's Avatar
Region: Nevada
It'll be hard to trouble shoot that one over the net, but it seems to me like you might have a fuel problem? ( bad injector (s) , possibly fuel pump or filter )
The fuel pumps on mustangs are notorious for going bad at about 65k to 75k miles.
Good luck and sorry you're having problems.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 10-02-2013, 06:12 PM   #6
NewMtang's Avatar
First clean little car.
So who did the curb rubbing you your rim?
Does it feel like it won't shift into different gears (transmission problem)?
Outside temperature of 65 is not very hot outside.
How does it run when just idling?
Check your fluid levels and find a transmission stop near your house. That may be your problem.
How long has this been happening?
If this just started recently, any chance of having purchased bad gas?
Have your run any fuel cleaners through your fuel system?
Not sure on what else to tell you to look. How about I send you Three Hail Marys and Cross My Fingers?
GOOD LUCK!
Old 10-02-2013, 06:52 PM   #7
Mustang has 144000 miles on it so that might be it... But it runs perfect idling nothing wrong.. It does feel like it doesn't want to shift at all.. It'll ride on 2rpm then finally shift this has been going on for about 2 years I just try not to run it when it's to hot... Hoping it was just the radiator no such luck
Old 10-02-2013, 06:57 PM   #8
check your pcv valve
Old 10-02-2013, 07:38 PM   #9
Lol I meant shift! But ill give it a shot thank u!
Old 10-02-2013, 11:05 PM   #10
Try seafoam
Old 10-02-2013, 11:34 PM   #11
NewMtang's Avatar
Might be the bands on the transmission. It's good that's it isn't doing it while idling. Has it been doing this since you got the car?
Old 10-04-2013, 01:21 PM   #12
Yup it's happened since I got it
Old 10-04-2013, 03:25 PM   #13
Surffer227's Avatar
Check tranny fluid level, most likely a leak
Surffer227 is offline   Reply With Quote
Old 10-06-2013, 04:42 PM   #14
No leak tranny fluid is good
Old 10-06-2013, 04:47 PM   #15
Check the trans fluid and see what color it is should be a red
Old 10-07-2013, 06:43 PM   #16
SueK's Avatar
It does sound the bands. I had that happen years ago. It'll have trouble moving.
SueK is offline   Reply With Quote
Old 10-08-2013, 08:25 AM   #17
tonyd01gt's Avatar
+1 on the color of the fluid. if brownish, you should try changing the fluid and putting in a new filter.also, try Lucas transmission fix, have seen it work on many transmission in the past.
tonyd01gt is offline   Reply With Quote
Old 10-08-2013, 10:34 AM   #18
SueK's Avatar
Yes that too. Most be people neglect changing the fluid and filter after 100,000 miles. Same with brake fluid and other fluids.
Old 10-08-2013, 11:08 AM   #19
Vsixpower's Avatar
I wouldnt change ur tranny fliud, if u havent changed it every 30,000 miles like its recommended it can cause more problems like it slipping more n possibly break on u.
Vsixpower is offline   Reply With Quote
Old 10-08-2013, 02:09 PM   #20
Project Pony's Avatar
You have it drained and filled if its higher mileage and hasn't had regular flushes. People run into problems flushing with high miles because it knocks all the built up crud loose. And shortly after they find themselves needing the tranny rebuilt. You just need to stay away from a pressurized flush.
[SIGPIC][/SIGPIC]
Old 10-08-2013, 07:35 PM   #21
SueK's Avatar
Yes if it hasn't been done before, I think that's what I forgot to add. So am I understanding this right, I still run the risk if I drain it after a 100,000 miles or is that just for the pressurized flush? I would think defiantly the pressurized flush. Thanks for bringing that up.
Old 10-09-2013, 05:31 AM   #22
No risk in a drain and fill.
[SIGPIC][/SIGPIC]
Old 10-09-2013, 07:34 AM   #23
SueK's Avatar
Didn't think so. Thanks. I like to know all these things in case the old fashioned way is not always the good way. That's what I'm here for, To learn. Thanks again.
Old 10-14-2013, 09:33 PM   #24
Yeah tranny rebuilds trying to avoid that one haha thanks
Old 10-15-2013, 06:21 AM   #25
SueK's Avatar
You're telling me! HAHAHAHA MONEY MONEY MONEY.
12:58 PM
