Spark plugs - Mustang Evolution
Old 10-23-2013, 02:07 PM   #1
Mike V.'s Avatar
Spark plugs
What spark plugs do you guys recommend using? 03 automatic
Mike V. is offline   Reply With Quote
Old 10-23-2013, 02:23 PM   #2
Site Sponsor
Sponsor
AMWill's Avatar
There's a couple good choices for which spark plugs to use. You'll also find a lot of strong opinions on which ones are better than others. So, I suggest trying a few searches on the forum to help your decision.
For an '03 v6, we normally would use the NGK Iridium IX plugs. They have a stock heat range of 5, and have iridium tips. So you can expect the plugs to last MUCH longer than any copper plug. It's not uncommon for these to last 80k miles!
This would be my first choice for any DD New Edge Mustang!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 10-23-2013, 02:29 PM   #3
Horseplay's Avatar
ford motorcraft and call it a day. trust me
Low2v
Old 10-23-2013, 03:12 PM   #4
lemons95's Avatar
No need to get expensive spark plugs with these engines, Only time my auto teacher recommended the higher grade spark plugs was for a ford modular engine, because he didn't like to change them on it and the higher grade ones are suppose to last longer.
Don't get like the dirt cheap ones though, like the next step up.
Old 10-23-2013, 03:34 PM   #5
Mike V.'s Avatar
Do you need a special tool to change them?
Old 10-23-2013, 03:36 PM   #6
Project Pony's Avatar
Not really, just a spark plug socket and a basic ratchet set. Extensions help alot.
[SIGPIC][/SIGPIC]
Old 10-23-2013, 04:26 PM   #7
Crowned1's Avatar
+1
Crowned1 is offline   Reply With Quote
Old 10-23-2013, 06:14 PM   #8
Rm360's Avatar
+2 !!
Old 10-23-2013, 06:33 PM   #9
bkh1994's Avatar
Motorcraft Platinum/Spark Plug (SP-486) | 2003 Ford Mustang 6 Cylinders 4 3.8L SFI | AutoZone.com
Use these, they are cheap and what came on the car to begin with. You might want to get some antiseize to put on them before you put them in, itll help when you go to take them out next time. All you need is a ratchet and spark plug socket. If it's your first time, expect 1-2 hours
bkh1994 is offline   Reply With Quote
Old 10-23-2013, 07:23 PM   #10
1-2 hours?! My first time on my first stang took no more than 30 minutes. Now I can have em all swapped out in about 15 minutes.
They do come from the factory with motorcraft platinums, however going with the motorcraft coppers has shown a noticeable difference in performance and fuel economy. Combine those with the MSD streetfire coil pack and MSD wires and your good to go.
[SIGPIC][/SIGPIC]
Old 10-23-2013, 07:38 PM   #11
Motorcraft/Autolite coppers.
Old 10-23-2013, 08:19 PM   #12
Mike V.'s Avatar
Thanks a lot guys I'm gonna go with the motorcraft coppers
Old 10-24-2013, 08:46 AM   #13
bkh1994's Avatar
That's how long it took me and it was my first time. It's hard reaching all of them
Old 10-24-2013, 09:27 AM   #14
Extentions and swivel sockets make it very easy. Mine is trickier with the strut tower brace and cai in the way on the passenger side. But even then it only takes a minute or so to pull the cai. Then I have plenty of room to get around the brace.
[SIGPIC][/SIGPIC]
Old 10-24-2013, 09:28 AM   #15
1lowGT's Avatar
Make sure you got the correct gap and don't over tighten them
Old 10-24-2013, 09:28 AM   #16
Gap em at .54
[SIGPIC][/SIGPIC]
Old 10-24-2013, 09:33 AM   #17
BlackSmoke02's Avatar
I had mine gapped at .53 any difference?
BlackSmoke02 is offline   Reply With Quote
Old 10-24-2013, 04:17 PM   #18
Mike V.'s Avatar
Yea I gapped them at .054 and ended up buying the motorcraft platinums. It was my first time and took about an hour and a half. Runs so much nicer! Thanks for the help guys
Old 10-24-2013, 04:18 PM   #19
Mike V.'s Avatar
One of the old plugs. I had 2 that were a lot worse
Old 10-24-2013, 09:14 PM   #20
1lowGT's Avatar
Wow good thing you replaced them. No the recomendation is .052-.056 i just went with the middle
Old 10-27-2013, 04:12 AM   #21
PureInstinct's Avatar
Looks like I'm a tad late on this thread. I run NGK Iridium IX spark plugs on my '04 V6 and I gotta say that I do love them. But hey, both NGK and Motorcraft are good; and you definitely did your car a favor by changing your old ones out!
PureInstinct is offline   Reply With Quote
10:46 AM
