Help on rear end and some pointers on tuning - Mustang Evolution
Old 10-24-2013, 02:47 AM   #1
671stang's Avatar
How can you check if the rear end has been changed out I wanna swap out to a gt rear end but idk if it has been swapped . My car gets off the line quick
Also need some tuning pointers I just had a true duel exhaust flow master thunder kit put in
671stang is offline   Reply With Quote
Old 10-24-2013, 03:12 AM   #2
lemons95's Avatar
Pull a burnout and look for two tire marks. GT rear ends have a locker stock, v6 rear ends are open and spin one wheel.
Old 10-24-2013, 04:17 AM   #3
ColeJohnson's Avatar
Originally Posted by 671stang View Post
How can you check if the rear end has been changed out I wanna swap out to a gt rear end but idk if it has been swapped . My car gets off the line quick Also need some tuning pointers I just had a true duel exhaust flow master thunder kit put in
Like the person above me said the easiest and lost fun way to find out is to roast the tires and see if they both lock. If they both lock then you're good to go.
As far as tuning you won't need any tune for just exhaust. Honestly you won't need to tune for anything unless you do drastic intake changes such as try to put a huge MM tb/ upper plenum or do internal engine/ head and cam work or go with forced induction. Also you might wanna use a tuner to correct the speedo after a gear swap or to turn off rear 02s after switching to an o/r pipe.
2016 Comp Orange GT (current)
Old 10-24-2013, 05:36 AM   #4
671stang's Avatar
Just burned out ant turns out it both spin out so that's good and thanks for the help will p/u headers and cai tomorrow tuner next week any specific brand that works
Good on our cars also will it turn off o2
Old 10-24-2013, 06:50 AM   #5
Just burned out ant turns out it both spin out so that's good and thanks for the help will p/u headers and cai tomorrow tuner next week any specific brand that works Good on our cars also will it turn off o2
I have a SCT tuner. The X3 I think. It works okay but there are better ones out there.
Yes. You can turn off rear 02s.
04:18 AM
