chirps - Mustang Evolution
Old 10-25-2013, 09:31 PM   #1
Dpred03's Avatar
chirps
I am having a some issues . There are random, non-consistent chirping noises that i thought was the belt, but after replacing the belt it still chirps. Sometimes the chirping is quiet, sometimes its loud, very loud. Secondly, the car stalled when coming to a stop (and the chirp is loud) . My car is an automatic. Any info would be great, thanks
Dpred03 is offline   Reply With Quote
Old 10-26-2013, 09:03 AM   #2
tc x 4's Avatar
Since you've replaced the belt, I'm guessing it's a bearing going out. Get a dowel rod / stethoscope, and touch it to each of your engine components while holding the other end to your ear. You should be able to hear which one it is.
Old 10-26-2013, 09:11 AM   #3
Dpred03's Avatar
Once I figure it out then that pulley needs to be replaced?
Old 10-26-2013, 09:17 AM   #4
tc x 4's Avatar
It will be the bearing on the pulleys shaft. The component will need rebuilt/replaced. Be sure to check the idler pulley, that's usually what goes out first.
Old 10-27-2013, 01:56 AM   #5
sam62893's Avatar
First, take your belt off and check each pulley one by one. Check if they spin smoothly or harsh. If you feel any sort of abnormalities the bearing and/or pulley is bad. Remove and replace
04:14 AM
