Weird noise when pressing and releasing brake 2000 mustang manual. - Mustang Evolution
Old 10-30-2013, 02:31 PM   #1
Veracadoro's Avatar
As stated in the title I am hearing a low almost grumble sound when I press and release my brake. Car stopped both on a hill and flat street still making the sound. Is this normal or an early issue sign?
Veracadoro is offline   Reply With Quote
Old 11-01-2013, 02:53 AM   #2
PureInstinct's Avatar
It sounds to me like you need new wheel bearings. They tend to make that sound when they need to be replaced.
PureInstinct is offline   Reply With Quote
Old 11-01-2013, 03:02 AM   #3
Veracadoro's Avatar
Is that even when the car is not in motion? Because with the car at a standstill it still makes the noise. And it's from more of a rough pressing on the brake and releasing
Old 11-01-2013, 11:22 AM   #4
Oh, I overlooked the "not in motion part" ...I've never had any problems while my car is at a still-point, so I wouldn't know what to tell ya.
Have you checked the brake pads and rotors? When the brake pads are low they have a high pitched squeak or squeal, but when they are completely bad they also give off a "low, almost grumble" sound. Are they worn down to the point where metal is grinding with metal?
Again, I've only heard all of these sounds when in motion, so these are my best guesses.
Old 11-01-2013, 11:25 AM   #5
Veracadoro's Avatar
I'm not sure really. I just replaced the front brakes soon. And it occurs when pumping the brakes at a stand still in almost clueless as to what it is
Old 07-02-2014, 04:07 PM   #6
Iryan7's Avatar
Ever find the problem? Mine makes a creeping sound when I press the brakes, even in motion. Any help would be awesome.
Iryan7 is offline   Reply With Quote
Old 07-02-2014, 04:09 PM   #7
Veracadoro's Avatar
Chalked up to "mustang quirks" my friends mach 1 does the same thing
Old 07-03-2014, 04:47 AM   #8
Bravebowhunter's Avatar
Where is the noise coming from? I had a weird noise similar to how your describing in my old jeep wrangler and it turned out to be a nylon bushing that was on the brake rod that goes from the pedal through the firewall to the booster it was missing... Might want to get under there and check to see if there is one, part of one, any sign of one being there. Let me know!
1967 coupe 351w 5 speed dual exhaust, 2000 v6 5 speed dual exhaust, 2005 ford ranger single cab 3.0 auto
Bravebowhunter is offline   Reply With Quote
10:37 PM
