throttle body help? - Mustang Evolution
Old 11-04-2013, 06:23 PM   #1
throttle body help?
will a throttle body off a stock 4.6l fit my 3.6 and would it have any performance advantage now or in the future ?
smokeyy is offline   Reply With Quote
Old 11-04-2013, 09:18 PM   #2
Region: Rhode Island
Don't think so but you can check the fit by pulling up the specs on the throttle body and see if it fits your engine. You can google it or go to eBay pull up that throttle body and check your car for fit as eBay requires all parts to be linked to what engines it will or will not work on.
Thomashogan640 is offline   Reply With Quote
Old 11-05-2013, 01:38 PM   #3
davidcseifert's Avatar
Region: Arkansas
The bolts line up, but gts use a remote mount iac stock so you would have to also remote mount your iac valve as in stock position it's useless since there is no port in the TB to let it work.
blower/new cam soon
02:17 AM
