Throttle modification - Mustang Evolution
Old 11-04-2013, 09:02 PM   #1
Mike V.'s Avatar
What is the throttle modification that takes out the slack from the pedal?
Mike V. is offline   Reply With Quote
Old 11-04-2013, 09:22 PM   #2
v8pony's Avatar
Put your seat back as far as it can go, lay down and get in a position to look up on your gas pedal, now when your looking at the back of it look where the throttle cable is connected to the pedal, you want to pull the pedal all the way, and use either a zip tie, or gear/hose clamp to be placed right at the end of the throttle cable right near the pedal, therefor taking out any slack...really once you get under there you will know exactly what to do, it really is so simple unless your a bit big, than may require removing the drivers seat, but once you see it down there, it's common sense.
2002 5spd GT
Feb 2013 Mustang of the Month
Old 11-04-2013, 09:50 PM   #3
Most get a nylon spacer for like $.05 and put it in there with a small clamp.
Old 11-05-2013, 05:29 AM   #4
mystang50's Avatar
is this only for new edge? I've never heard of this before?
Old 11-05-2013, 06:21 AM   #5
v8pony's Avatar
+1
---------- Post added at 08:21 AM ---------- Previous post was at 08:20 AM ----------
I believe so , never know tho, get under there and check it out!
2002 5spd GT
Old 11-05-2013, 09:56 AM   #6
sebasflorez's Avatar
It actually works for sn95, new edges and 05-09 s197's. They all have that slack
sebasflorez is offline   Reply With Quote
Old 11-05-2013, 10:25 AM   #7
v8pony's Avatar
Wow, good to know!
2002 5spd GT
Old 11-05-2013, 07:49 PM   #8
Mike V.'s Avatar
I just used a few zip ties and it feels good! I love the response
Old 11-05-2013, 08:16 PM   #9
v8pony's Avatar
Oh yea very simple yet very effective
2002 5spd GT
01:20 PM
