2001 mustang blinkers - Mustang Evolution
Old 11-11-2013, 10:08 PM   #1
Jsansom's Avatar
My Gfs car.. Hit the blinker (either way) some times it will be fine sometimes it will blink 2-3 times then quit (while the switch is up or down) then sometimes it don't do anythin at all.. Ideas??
Jsansom is offline   Reply With Quote
Old 11-12-2013, 12:23 PM   #2
davidcseifert's Avatar
Region: Arkansas
Couple things, the flasher relay under dash (it was a yellow box above the OBD2 port on my car) it's about $6. I had a problem with a wire coming out of my harness to the blinker switch, easy to check just need a 8mm to remove the two plates below the steering wheel and a Philips screw driver to remove the column cover, make sure all the wires are pushed in and making full contact. If neither works, the switch itself is most likely going bad, you can either get one from a junkyard or the parts store can order one (AM has one but it's a little more costly than a normal parts store last I saw).
blower/new cam soon
Old 11-12-2013, 05:56 PM   #3
Jsansom's Avatar
Alright thanks man I'll check those tomorrow. And I'll let u know thanks for the help
03:30 PM
