Roof dome light - Mustang Evolution
Old 11-12-2013, 06:08 PM   #1
MustangDani's Avatar
Roof dome light
So I just bought a 2002 V6 mustang and my dome light on the roof never turns off? It drains my battery a ton and sometimes I need a jump, I took out the bulb so I don't have that problem but now when I get into my car at night I can't see **** without manually turning on the side lights on the dome, so what can I do?
MustangDani is offline   Reply With Quote
Old 11-12-2013, 06:56 PM   #2
clflorida's Avatar
Region: Arkansas
I use my phone....
clflorida is offline   Reply With Quote
Old 11-12-2013, 07:10 PM   #3
clflorida's Avatar
Region: Arkansas
Using google, someone said turn your headlight knob clockwise, take out the bulb, or get new wiring for it. It could also be the door isn't closed all the way..
Mine doesn't turn on when I open the door so idk why yours would..
---------- Post added at 08:10 PM ---------- Previous post was at 08:05 PM ----------
Before you try to rewire it. http://www.moddedmustangs.com/forums...ght-stays.html
Old 11-13-2013, 12:00 PM   #4
sam62893's Avatar
Could be you left your light on. There's 3 total bulbs in there. And the headlight knob turns on the middle one. The headlight knob is a dinner switch also which dims your gauge cluster and if turned counter clockwise till it clicks it turns on your interior light
Old 11-14-2013, 09:25 AM   #5
Sluder4's Avatar
Mine if you don't lock the doors when you get out with the remote they won't turn off. You also have to turn it counter cliques to where it clicks and it'll go off. Mine used to be the same way when I bought some green LEDs for the dome light that someone had removed.
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
11:26 PM
