interior lights? - Mustang Evolution
Old 11-12-2013, 07:37 PM   #1
TylerHo1313's Avatar
interior lights?
I am a first time mustang owner. So I do apologize for my lack of knowledge.
On a 2001 mustang do the interior lights come on when the drivers door is open?
TylerHo1313 is offline   Reply With Quote
Old 11-12-2013, 07:44 PM   #2
samuelsmith's Avatar
Yes, if you hear that stupid ding the door pin works right and probably the bulb is blown. Check by turning the head light switch to c if the dome light comes on. The 2 map lights come on and the switch is located next to the dome light.
Old 11-12-2013, 08:02 PM   #3
TheBandit's Avatar
Yes the dome light should come on when you open the door. If the bulb is good the usual problem that plagues this chassis style is the dimmer/ headlight switch itself. I had the same issue with my 02 gt and replaced the headlight/dimmer switch and it fixed the problems I had.
Good Luck!
TheBandit is offline   Reply With Quote
Old 11-12-2013, 08:04 PM   #4
Okay thanks ill have to check those two possible causes out
Old 11-14-2013, 09:27 AM   #5
Sluder4's Avatar
A lot of people remove their dome lights like someone did before I bought mine. Might wanna pop off the dome and see
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 11-14-2013, 06:15 PM   #6
I have interior lights if I turn them on from light switch. ..would it be something in the door?
Old 11-14-2013, 06:29 PM   #7
Adogg's Avatar
I would check the little switch that's in the door jam it looks like a button, it might be stuck, it was like that on my car for awhile.
Don't hate....... appreciate
Old 11-14-2013, 06:30 PM   #8
Ok ill check it out tomorrow
02:00 PM
