4.2 swap build list - Mustang Evolution
Old 11-17-2013, 06:33 PM   #1
mummert_96v6's Avatar
4.2 swap build list
Alright I've got a 1996 six banger and it's got 226xxx on it. I just bought a truck for winter and I'm out of high school in a lil over a month. So my plan is to pull the ole tired out 3.8 out and put a nice 4.2 back in. Who knows what all I need I keeping with the single port but I need a build list can someone help me out?
mummert_96v6 is offline   Reply With Quote
Old 11-17-2013, 06:52 PM   #2
97cutomstang's Avatar
4.2 crank, 4.2 pistons, 4.2 harmonic balancer. If you get the harmonic balancer from a 97-98 you can reuse your crank pully.
97cutomstang is offline   Reply With Quote
Old 11-17-2013, 07:58 PM   #3
dont I need an oil pan from a 01-04?
Old 11-17-2013, 09:25 PM   #4
baddbradd's Avatar
That's my question too. After the first of the year, I'm gonna start collecting parts for this myself
baddbradd is offline   Reply With Quote
Old 11-17-2013, 09:26 PM   #5
lemons95's Avatar
YES! get an 01-04 oil pan. I didnt and my leaks a little bit.
Old 11-17-2013, 10:50 PM   #6
davidcseifert's Avatar
Region: Arkansas
01-04 oil pan and pick up tube, there is a complete swap listed for each year model of car and a parts list of what you need at the top of this section.
blower/new cam soon
Old 11-18-2013, 05:47 AM   #7
I reused my 97 oil pan and pick up tube and have no problems.
Old 11-18-2013, 09:07 AM   #8
Region: Arkansas
Aren't you the one who cut the main studs in the fb group to make the pan clear the 4.2 mains?
blower/new cam soon
Old 11-18-2013, 09:35 AM   #9
No. I didn't cut anything. I used everything from my stock 3.8 block.
Old 11-18-2013, 09:49 AM   #10
Region: Arkansas
Oh my bad, saw some guy do that to his singleport, :facepalm everywhere lol
blower/new cam soon
Old 11-18-2013, 11:43 AM   #11
samuelsmith's Avatar
It doesn't include that a tune is needed. I guess, it is expected knowledge.
Old 11-18-2013, 11:57 AM   #12
can you get a tune from bama?
Old 11-18-2013, 12:42 PM   #13
xhgwx's Avatar
They won't touch if unless it's in house on their dyno...
I've asked
---------- Post added at 01:42 PM ---------- Previous post was at 01:42 PM ----------
Or a build like urs I mean
xhgwx is offline   Reply With Quote
Old 11-18-2013, 12:56 PM   #14
Originally Posted by xhgwx View Post
They won't touch if unless it's in house on their dyno... I've asked ---------- Post added at 01:42 PM ---------- Previous post was at 01:42 PM ---------- Or a build like urs I mean
So where do you get a tune for it then?
Old 11-18-2013, 01:01 PM   #15
xhgwx's Avatar
Trailer it to a dyno tuner.
Old 11-18-2013, 01:04 PM   #16
if I do that can I still get a bama three stage tuner after the computer is tuned for the 4.2?
Old 11-18-2013, 01:10 PM   #17
xhgwx's Avatar
Correct get the SCT tuner from Bama, but any mod after the 4.2 swap that needs a tune will most likely need a dyno tune unless Bama can modify the stock 4.2l dyno tune to let's say you add LTs, to accommodate for that
Old 11-18-2013, 01:36 PM   #18
Region: Arkansas
I can get you a tune for the build
Luis tuned mine via email and outdone my dyno tune in both track times and mileage lol..
Edit: if you have it tuned by one person another tuner can not modify their file! You would have to get the actual tune file not the .cef that is loaded to the tuner (in reply to the last post)
blower/new cam soon
Old 11-18-2013, 08:58 PM   #19
Originally Posted by davidcseifert View Post
I can get you a tune for the build Luis tuned mine via email and outdone my dyno tune in both track times and mileage lol.. Edit: if you have it tuned by one person another tuner can not modify their file! You would have to get the actual tune file not the .cef that is loaded to the tuner (in reply to the last post)
Sweet I'll definitely be getting ahold of you for that tune David and a regrind then. Can I run stock lifters with that cam though? I wanna change rockers to something a lil bigger, if I'm not mistaken stock rockers are 1.73s correct?
Old 11-18-2013, 10:16 PM   #20
The car will run without a tune, but you will wish you never cranked it.
It depends of the cam. If you want performance, get a cam that needs rockers. I bought rockers, springs and lifters. Building a engine will nickel and dime you. Take your time and ask yourself, "do I want to do it right the first time". If not you will find your self going back into the engine and finishing what you started. But, you can get a good mid. performance cam without breaking the bank.
I herd certain cams with big valve lift need the heads to be port n polished. If not the exhaust gasses can not escape and will cause the oil pan to crack.
Here are the most common cam options. LOL have fun deciding
rpm-mustang cam spec
207/215 .493/.495 110LCA 112ICL
212/224 .531/.519 112LCA 112ICL
215/220 .573/.537 108LCA 112ICL
Common camshafts
207/207 .505/.505 110LCA-- budget cam swap with a good flowing exhaust
207/209 .493/.491 110LCA-- budget cam swap with moderate flowing exhaust
207/215 .505/.495 110/2LCA-- budget cam swap with restrictive exhaust
216/224 .507/.519 112LCA- aggressive 4.2L cam with heads, intakes, etc
215/225 .495/.491 112LCA- mild singleport 3.8L poweradder cam
220/225 .538/.521 110LCA- aggressive singleport 3.8L cam
224/228 .519/.514 110LCA - aggressive singleport 4.2L cam
MORANAV6RACING
210/210 .480/.480 115LCA 115ICL "A" CAM
220/220 .538/.538 110LCA 110ICL "C" CAM
SUPERSIXMOTORSPORTS
212/212 .550/.550 1.7 114LCA Stock 3.8 turbos
212/218 .550/.550 1.7 110LCA Stock automatics
218/218 .550/.550 1.7 114LCA 3.8 turbos
218/224 .550/.550 1.7 112LCA Supercharged 3.8, 5-speeds, high stall
224/224 .550/.550 1.7 114LCA Stroker turbo
224/230 .550/.550 1.7 114LCA Supercharged strokers, 10:1
230/236 .550/.560 1.7 114LCA 11:1, big superchargers
Compcams
200/208 .480/.480 112LCA 108ICL 255HR112 44-700-9 89-PRESENT
204/216 .480/.480 115LCA 108ICL 259HR115 44-701-9 89-PRESENT
210/218 .500/.500 112LCA 108ICL 268HR112 44-702-9 89-PRESENT
210/226 .500/.500 115LCA 108ICL 265HR112 44-703-9 89-PRESENT
218/226 .500/.500 112LCA 108ICL 273HR112 44-704-9 89-PRESENT
Old 11-18-2013, 11:22 PM   #21
Region: Arkansas
Depends how worn they are, generally if you have 100K or more it's a good idea to go ahead and replace them (cool thing is you can use the lifters out of a 302!)
I'm using these in my car
Ford Racing Hydraulic Mustang Roller Lifter Kit - 5.0/5.8 M-6500-R302 (86-95 5.0L) - Free Shipping M-6500-R302
Yes stock is 1.73, harland sharp makes some 1.8's which with a regrind cam would work to your advantage since I can't have to large of an amount ground off it. Would get you another couple hundredths lift or so lol
blower/new cam soon
Old 11-20-2013, 11:09 AM   #22
Depends how worn they are, generally if you have 100K or more it's a good idea to go ahead and replace them (cool thing is you can use the lifters out of a 302!) I'm using these in my car Ford Racing Hydraulic Mustang Roller Lifter Kit - 5.0/5.8 M-6500-R302 (86-95 5.0L) - Free Shipping M-6500-R302 Yes stock is 1.73, harland sharp makes some 1.8's which with a regrind cam would work to your advantage since I can't have to large of an amount ground off it. Would get you another couple hundredths lift or so lol
Yea I planed on buying new lol. Will 1.8 rockers fit under stock valve covers?
Old 11-20-2013, 02:32 PM   #23
Region: Arkansas
As far as I know they don't sit any taller than other rockers, that would be a good question to call and ask about
blower/new cam soon
Old 11-20-2013, 08:25 PM   #24
what size rockers do you run?
Old 11-20-2013, 09:02 PM   #25
Region: Arkansas
Comp 1.7 pro magnums rollers
blower/new cam soon
Old 11-20-2013, 10:23 PM   #26
+1
Old 11-21-2013, 08:58 AM   #27
Probably a stupid question but Do I need longer pushrods for that regrind cam and 1.8 rockers?
Old 11-21-2013, 09:23 AM   #28
Region: Arkansas
Yes, you'll need to purchase a pushrod length checker to measure which length pushrod is needed for the cam
blower/new cam soon
Old 11-21-2013, 11:20 AM   #29
well I'll add that to the list haha
Old 11-21-2013, 03:14 PM   #30
Watch this...........push rod roller geometry - Bing Videos
Old 11-23-2013, 02:12 PM   #31
how would I get the tune flashed into the computer? And is it just a base tune or something else?
Old 11-23-2013, 10:28 PM   #32
Region: Arkansas
With the handheld it connects to the obd2 port under dash a few simple steps and it'll flash the car. The first tune is a base yes, then you datalog that so we can see what changes need to be made, he modifies then sends new tune via email. Datalog again with the new tune and see how it runs and if it requires further modification.
blower/new cam soon
Old 11-24-2013, 08:16 PM   #33
So I could just buy something like the bama hand held tuner then and tune it that way?
Old 11-24-2013, 09:33 PM   #34
Region: Arkansas
Luis sells the same handheld and won't turn down tuning your car because it has more than bolt ons lol
blower/new cam soon
Old 11-25-2013, 01:21 PM   #35
sweet that makes him a one stop shop
03:54 PM
