Ported Upper Intake - Mustang Evolution
Old 11-19-2013, 01:46 PM   #1
2000stanguy's Avatar
Ported Upper Intake
I have a cai and dual exhaust what kind of gains would I see from just a ported upper? There is one for sale around me. How much is it worth. Thanks
Performance Red 2000 v6- m112 supercharger,42lb green top injectors, 310lph fuel pump, BBK shorty headers, True dual exhaust, strut tower brace, GT rear sway bar, Steeda triax short throw shifter, SR lowering springs, tinted headlights and foglights, polk audio speakers, MTX subwoofer, Kenwood head unit and black leather interior.
2000stanguy is offline   Reply With Quote
Old 11-19-2013, 02:28 PM   #2
davidcseifert's Avatar
Region: Arkansas
Pictures?
Honestly a windstar will outperform a stock upper by far, unless you went through the trouble of getting a cut/weld upper intake which is big money and still a close call when compared with the windstar upper intake
blower/new cam soon
Old 11-19-2013, 02:32 PM   #3
Originally Posted by davidcseifert View Post
Pictures? Honestly a windstar will outperform a stock upper by far, unless you went through the trouble of getting a cut/weld upper intake which is big money and still a close call when compared with the windstar upper intake
I don't have any pictures. What do you want to see? How much does it cost to piece together a windstar intake because they don't sell the kits anymore right?
Old 11-19-2013, 02:34 PM   #4
Region: Arkansas
Picture of exit compared to a gasket would tell you how much it's been touched.
If you can make your own parts $100 or so
blower/new cam soon
Old 11-19-2013, 02:56 PM   #5
Region: Arkansas
You perhaps referring to this post? Just saw it today
blower/new cam soon
Old 11-19-2013, 03:28 PM   #6
samuelsmith's Avatar
The windstar is a better intake. I use to recommend the 4.2 intake, but after a tune, everything changed, I noticed the power band is too high and does not perform properly at lower R.P.M.s, The windstar tunes better and 7 hp/ 15 tq at rear wheels.
Vap has a step by step IAC delete on the web sight
Old 11-19-2013, 03:40 PM   #7
Haha yea. That's what I have been looking at... Do you think I would feel a hp gain? I thought the windstar would cost more than that. I think I have seen write ups before but does anyone have a parts list of what I will need to fabricate or buy to make the windstar work?
Old 11-19-2013, 04:25 PM   #8
Region: Arkansas
You must be josh then :p I asked him the same question about the porting on the fb post lol
For that "ported" upper he probably took it off touched up the bottom of intake and called it good, doubt it would be worth much more than 2-3hp
I have a write-up on my laptop that a friend did, he did everything junkyard style but mounted the iac up top because he cut a hole under his gt good scoop. Iirc it has a parts list, if you want I can email it to you.
blower/new cam soon
Old 11-19-2013, 05:15 PM   #9
Thanks for the write up. The windstar intake won't clear a 94-95 strut tower brace will it?
Old 11-19-2013, 05:38 PM   #10
Region: Arkansas
You can try, I've only seen a bbk one clear it though
blower/new cam soon
Old 11-19-2013, 05:41 PM   #11
Ok thanks I will be doing some research and seeing if I can do this.
Old 11-19-2013, 05:50 PM   #12
bkh1994's Avatar
Could you email it to me also?
bkh1994 is offline   Reply With Quote
Old 11-20-2013, 02:33 PM   #13
Region: Arkansas
Sure send me your email I'll send it later
blower/new cam soon
Old 11-21-2013, 03:26 PM   #14
VAP Auto - Support
/support/Windstar kit install
Old 11-21-2013, 06:39 PM   #15
bkh1994's Avatar
Originally Posted by samuelsmith View Post
VAP Auto - Support
Thanks!
10:31 PM
