96-98 Manifolds - Mustang Evolution
Old 11-20-2013, 07:49 PM   #1
baddbradd's Avatar
96-98 Manifolds
I read the 1st sticky in this section about exhaust. I am only providing a few pics and sharing what I did,.. My 01 v6 had a cracked "replacement" manifold. It looks closer to a "log" style as opposed a typical shorty header. I have previously done this before a while back on a 98 v6 I had built. Any way, new to me 96-98 headers($40 shipped from a "corral" member). I welded around the outside of the tubes for each port, then ground out the inside weld. I do not have that pic, sorry lol. But just imagine it .. Anyway the 2 pics I do have is from the stock cracked takeoff manifolds. The i.d. of the collector is 2". That is tiny... The i.d. of the 96-98 shorty is 2.19" , I basically just "cleaned out" the collector and its opened up to 2.25"... Now for $40 plus a little time, I believe I have something just as good as a shorty with out spending $150. Plus, I like the idea of using junk and improving it so-to-speak.
2001 coupe
baddbradd is offline   Reply With Quote
Old 11-20-2013, 07:52 PM   #2
baddbradd's Avatar
Also, I am hooking these up to an H-pipe(I know its even fire engine) and a factory "bullet" catback. The h pipe is 2.5" and the catback is 2.25". With a small v-6 I really believe a full 2.5" isn't necessary, especially n/a. Anyway, maybe this could help someone
2001 coupe
Old 11-20-2013, 10:12 PM   #3
samuelsmith's Avatar
I have a set. A guy on here calls them turbo headers. The only bad thing is they rust the under carriage. It does not matter if you paint them they will still rust. I recommend spaying the area with a bed liner spray.
Old 11-21-2013, 07:29 AM   #4
baddbradd's Avatar
mine have the surface rust. I "remember when" my brother would heat his headers, off the car of course, with an acetylene torch then rub them down with trans fluid. This was back before thermal coatings Maybe 25 yrs ago. never rusted. My nephew says some circle trackers still do this. No rust. but ugly for sure.
2001 coupe
01:36 PM
