Possible Fuel Pressure issues - Mustang Evolution
Old 11-22-2013, 11:30 AM   #1
Before I get into the issue, I know that my fuel pump needs to be replaced as it seems to be going out due to sporadic drops in RPMs while moving
My car is a 1995, base model, 5 speed. When I get in to start it up after it has been sitting for a extended amount of time 2+ hours the engine will take a while to turn over I believe due to a lack of fuel pressure. However if the car is only off for less than that time, I typically do not have an issue starting it. The problem is also more noticeable when it is parked with the nose in the air.
I have discovered that if i try to turn it over, then immediately turn it off and try again, it starts up fine. When checking out my engine bay the other day, I noticed that one of the fuel lines had backed off its connection to the fuel rails by about 6-7 mm compared to the other one right next to, i pushed it back on.
One last thing, there is no noticeable fuel odor emanating from my car, fuel filter was replaced ~4 months ago. Can anyone shed some light on my car's issues
midsprat is offline   Reply With Quote
Old 11-22-2013, 04:28 PM   #2
samuelsmith's Avatar
Plug it in at Auto Zone and get some data log information.
Old 11-22-2013, 05:05 PM   #3
Even if the car is obd-I?
10:28 PM
