Update - Mustang Evolution
Old 11-30-2013, 11:48 AM   #1
ProjectTurboV6's Avatar
Update
So a lot as been done since I last logged in. So far I switched my exhaust to flowmaster 10 series mufflers and hollow cats. Heads, block, and crank are back from the machine shop so it's finally time to paint and reassemble :headbang. I gotta wait to save for the high compression pistons so I'm putting my car on a diet haha rear seat delete, completely gut the trunk, then tubular a arms and k member down the road. Hoping to be around 3000lbs with me inside
ProjectTurboV6 is offline   Reply With Quote
Old 11-30-2013, 11:59 AM   #2
It's not me, it's you.
primer2tone's Avatar
Sounds like an extensive build.
Old 11-30-2013, 12:09 PM   #3
Oh yeah, my 3.8 will be down for about a week so that I can switch parts over to the 4.2. There's still so much to buy haha plus I should rebuild the 8.8 and trans that's going in. Its definitely a money pit
Old 11-30-2013, 12:12 PM   #4
What's your target hp when all is said and done?
Old 11-30-2013, 12:13 PM   #5
Ideally 260-270rwhp no power adders
Old 11-30-2013, 12:22 PM   #6
That sounds reasonable. You auto or manual?
Old 11-30-2013, 12:31 PM   #7
Manual, with 3.90 gears and a solid tune I'm going for a 12SEC street car
Old 11-30-2013, 10:36 PM   #8
davidcseifert's Avatar
Region: Arkansas
Assuming its splitport swapped for the new heads with that goal Lol
Any flow specs on heads? What are the cam specs?
blower/new cam soon
Old 12-01-2013, 11:41 AM   #9
230/236 .55/.56 110lca and yeah it's a bored 4.2 with a decent amount of head work. The flow charts are at my work in my tool box. I'll make sure to get them Monday
Old 12-01-2013, 08:03 PM   #10
Region: Arkansas
That's a pretty hefty cam for N/A, should be interesting to see from a dig. Set the 2 step for 6K!
Here is what my heads managed with 1.9/1.5 valves. (numbers on right are current, heads were ported before and flowed the left numbers, then redone)
Name:	new heads flow numbers.jpg
blower/new cam soon
Old 12-01-2013, 09:04 PM   #11
Mine are 2/1.6 so I'm betting our numbers will be pretty similar. I went to the shop today to look for the flowchart and couldnt find them. I'll see if I can get a copy or something because I'm really not sure what the numbers should be
09:58 PM
