How To Install Speedo Gear On 98 Mustang V6! - Mustang Evolution
Old 12-01-2013, 01:10 AM   #1
I Have 98 mustang v6 with a 8.8 reared swap with the 3.73 gears in the rearend. I have order the speedo gear for that gear type and will like to know how to install the gear and how hard is it. Thanks
Doughd24 is offline   Reply With Quote
Old 12-01-2013, 07:10 PM   #2
Fourloko530's Avatar
Let me know to
Fourloko530 is offline   Reply With Quote
Old 12-02-2013, 06:27 PM   #3
mummert_96v6's Avatar
There is a sensor on the tail shaft of the trans. It's one bolt to pull the sensor then pull the clip off the gear pull the gear off the end of the sensor and reinstall it all the same way you took it apart with the new gear. Latemodelresto has a video showing you how to change it. It's like a 5min job really simple
mummert_96v6 is offline   Reply With Quote
02:10 PM
