Next Mods on 96 v6 - Mustang Evolution
Old 12-05-2013, 07:52 PM   #1
Shawnsta's Avatar
Next Mods on 96 v6
Hey all,
I've been reading past threads but I'm still not sure what I want to do next.
I currently have shorty headers, a cold air intake, dual exhaust.
I plan on getting this for Christmas:
- MGW short throw shifter
- Retro white shift knob
- White face reverse glow gauge insert
Now, what would you say would be the next mods to get after saving up work+holiday money?
I've heard:
- Tuner
- Gears
- 8.8 swap
How much would a tuner such as a BAMA tune help? (Stock gears, daily driver). I'm just looking to give the car a little more oomph, performance, and acceleration. Would a tuner be better before gears? If there is anything I'm missing, let me know, all ideas considered!
Thanks a bunch.
Shawnsta is offline   Reply With Quote
Old 12-06-2013, 09:44 AM   #2
Sluder4's Avatar
Tuner will be the best thing to get next. I'm in the same phase you are I need to get a tuner then do my 8.8 swap with some new higher ratio gears.
Then after that you'll be getting into the expensive stuff lol
You'll also eventually want some long tube headers and lower it a well. Long tube headers will get you some better flow an let the engine breath even more. Then after that you can get a bigger cam, frot and rear sway bars, and the bar that goes over the engine (idk why I can't think of it ATM!!!)
But yes a tuner should be your next purchase. Everyone says that's what they see the most gains from immediately out of everything when just starting to modify your stang.
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 12-06-2013, 11:48 AM   #3
davidcseifert's Avatar
Region: Arkansas
Tuner before gears, so that way when you swap the gears out you can fix your speedometer yourself and don't have to drive around with an incorrect speedo and odometer readings waiting till you can afford a tuner or a recalibration setup.
I can set you up with a tuner too if you're interested.
blower/new cam soon
Old 12-11-2013, 05:49 PM   #4
Shawnsta's Avatar
Thanks for the replies guys.
I've just ordered my MGW shifter and knob. A tuner will probably be next on my list!
12:11 PM
