SR short throw shifter problems - Mustang Evolution
Old 12-05-2013, 07:59 PM   #1
BamaStang93's Avatar
Hey guys, I'm having problems with the new SR short throw shifter I just bought for my 99 v6. Install went just fine, the shifter goes through all gears except reverse.. That's the first problem. Problem 2 is clearance. The shift knob is going into my radio everytime I shift into 1st, 3rd and 5th. Anybody ever had this same problem? If so, how did you fix it?
BamaStang93 is offline   Reply With Quote
Old 12-05-2013, 08:06 PM   #2
97cutomstang's Avatar
There should be two set screws one on top toward the radio and one opposite of that. They are supposed to stop the shifter after it goes into gear. Did you adjust them at all?
97cutomstang is offline   Reply With Quote
Old 12-05-2013, 08:09 PM   #3
I adjusted the bottom one, top one was a pain in the a$$ so I said forget it. But that may very well be the solution.
Old 12-05-2013, 08:20 PM   #4
Yea more then likely it is. Should be better when you adjust that. Not sure why you can't put it in reverse. I would double check that nothing fell in there blocking the handle from going all the way over.
Old 12-05-2013, 08:25 PM   #5
Ok so I went and finagled with the top screw. You were right, it's not knocking the radio now. So thanks man! But the whole reverse thing is really stumping me.
Old 12-05-2013, 08:35 PM   #6
No problem. Do you have the car running when you try to put it in reverse?
Old 12-05-2013, 08:47 PM   #7
Yes. See I thought during the install that it didn't go into reverse because the car is off. But when I crank it up, she still won't go into reverse...
Old 12-05-2013, 08:56 PM   #8
Hmmm... Try letting the clutch out some and see if it maybe falls into gear.
Old 12-06-2013, 07:00 AM   #9
mattyp511's Avatar
Region: New Mexico
My Sr short shifter was hitting my radio also... Turns out it came with the handle part bolted on backwards... Just turned it around and rebolted it and its normal
mattyp511 is offline   Reply With Quote
Old 12-06-2013, 07:32 AM   #10
sam62893's Avatar
Try fiddling around with the gears while the car is off and look for all of them. New shifter so you probably have to move it a certain way
Old 12-06-2013, 10:51 AM   #11
Are you talking about the two bolts that require the Allan key? I kinda think mine is backwards too. That's a good suggestion.
Old 12-06-2013, 01:37 PM   #12
Update
Looks great, drives great but still will not go into reverse..
Old 12-06-2013, 03:49 PM   #13
mattyp511's Avatar
Region: New Mexico
Yea those are exactly what I'm talking about haha.... Try n turn it around and see if it helps... I had to call american muscle when I had that problem and that's what they said to do, so try it.. you probably have the some problem I did. Just turn it around and you'll get like two more inches of clearance between your radio and shifter
Old 12-13-2013, 01:46 PM   #14
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Hey,
I'm sorry to hear about the issue you're having with your SR Performance Shifter. It's very odd that you can't get into reverse! I had this same shifter on my 2004 Mach 1 and didn't have any issues. However, I did have to adjust the screws so that it wouldn't hit the radio!
Please shoot me a PM with your order number and we'll look further into this for you. It may be something silly like a small adjustment, but if it's more serious than that we'll definitely get you taken care of right away! I look forward to your PM.
-Dan
Old 12-13-2013, 03:09 PM   #15
Originally Posted by AMDanBailer View Post
Hey,
-Dan
Thanks Dan! I appreciate it but I have already fixed the problem. I took it to my buddy that does transmissions and we figured that the spring under the gold plate was restricting the shifter from catching into gear. So we cut a coil off from the spring, put it back in the shifter and it went right into reverse! Now the shifts are firmer and quicker! That's why I love AM. Great product, great customer service!
Old 12-16-2013, 09:45 AM   #16
AmericanMuscle.com
Sponsor
Awesome! I'm glad to hear you got everything figured out. Definitely let me know if you run into any further issues and we'll address them right away!
Enjoy your shifter!
-Dan
07:34 PM
