Starting problem. - Mustang Evolution
Old 12-06-2013, 08:45 AM   #1
spartacus's Avatar
Region: Nebraska
Starting problem.
Alright so for the past couple months my 98 has had a starting problem. It almost always takes 2 trys to start unless you hold it. Except in the cold weather it is now taking sometimes 3 times to start. I got the starter checked out by AutoZone and they said it was still good. I replaced the spark plugs with high end iridium tipped ones and I check my battery and its still good. I just don't really have anywhere to check that I know of, it could be the fuel pump but I have to drop the tank to check that. Any advice on where to look, or what to test would be appreciated.
spartacus is offline   Reply With Quote
Old 12-06-2013, 11:41 AM   #2
davidcseifert's Avatar
Region: Arkansas
Sounds like the fuel rail isn't staying primed, next time try to start it by turning key on, then off, and back on then try to start, if it works its the fuel pump most likely.
blower/new cam soon
Old 12-08-2013, 12:37 AM   #3
Jowl7's Avatar
Is it automatic or manual?
Jowl7 is offline   Reply With Quote
Old 12-08-2013, 12:45 AM   #4
spartacus's Avatar
Region: Nebraska
its a manual
Old 12-08-2013, 12:57 AM   #5
Jowl7's Avatar
Check the clutch safety switch, ignition switch both cylinder and electrical.. If it was the fuel pump it would start and than eventually shut off. Also once running it would feel sluggish if the pump was bad
04:38 PM
