Even more problems - Mustang Evolution
Old 12-06-2013, 04:01 PM   #1
JimmyMosqueda's Avatar
Even more problems
2003 V6 has some sort of knocking noise coming from the rear of the car. Going over speed bumps and the car hits the bump BAD. Feels like my exhaust is taking a pounding, and I'm stumped. Any help is greatly appreciated.
JimmyMosqueda is offline   Reply With Quote
Old 12-06-2013, 04:17 PM   #2
samuelsmith's Avatar
Push down on the back of the car. If it is stiff the shocks are good. If it is springy the shocks are bad.
Old 12-06-2013, 04:25 PM   #3
Would the shocks be causing the knock noise as well?
Old 12-10-2013, 10:10 PM   #4
lemons95's Avatar
is it just going over speed bumps?
Is the sound coming from the rear or the rear-end differential?
Old 12-11-2013, 05:13 AM   #5
Just speed bumps. Figured out the sound is because the muffler hanger is a little loose. But my car still hits pretty bad:/
Old 12-11-2013, 12:52 PM   #6
lemons95's Avatar
It's probably the suspension mine does it, I had three guys sitting on the back and it did that.
My suspension works fine if I'm only the one in the car though.
Old 12-11-2013, 01:33 PM   #7
Same here, I just scrape instead of hitting the bottom lol
Old 12-14-2013, 05:52 PM   #8
Weeelll. Fixed the knocking, and the hitting. Swapped all 4 shocks/struts and re-tightened the mid-pipe bolts. They loosened since I replaced the manifolds with shorty headers.
Old 12-14-2013, 06:47 PM   #9
NewMtang's Avatar
Is Your mother-in-law still in the trunk? Open trunk, throw in one bottled water, close trunk, drive down the road.
Old 12-14-2013, 06:48 PM   #10
Seems like the only logical thing to do at this point lol
Old 12-14-2013, 10:40 PM   #11
v8pony's Avatar
Lmao +1
2002 5spd GT
Feb 2013 Mustang of the Month
Old 12-14-2013, 10:49 PM   #12
Why waste the water?
11:11 PM
