supercoupe supercharger on my 3.9L - Mustang Evolution
Old 12-08-2013, 12:27 PM   #1
rickbob's Avatar
I have heard that the super charger off of the 3.8L super coupes will bolt right on to my 3.9L (same motor different stroke) my problem is I've never seen anyone do it, if it really can be done
rickbob is offline   Reply With Quote
Old 12-08-2013, 03:46 PM   #2
sam62893's Avatar
Nope. Your engine is a split port and the blower uses the single port. So if you had an engine from 94-98 then yeah. In this case, no, it will not bolt on directly
Old 12-08-2013, 05:22 PM   #3
rickbob's Avatar
That makes me wonder if there even is a supercharger for the 3.9L or is there only turbo kits
Old 12-08-2013, 05:58 PM   #4
samuelsmith's Avatar
Why not put a super coupe supercharger on a 4.2? Most people go for the extra 5 hp
super coupe supercharger < M112 (Cobra supercharger)
the second video is what needs to be done if you have a complete super coupe single port motor. It is not that hard, but I can think of easier ways to get a extra 35 hp.
http://www.bing.com/videos/search?q=...AC8E0DE4703512
Old 12-08-2013, 09:23 PM   #5
sam62893's Avatar
M112 or a procharger.
Old 12-09-2013, 10:42 AM   #6
davidcseifert's Avatar
Region: Arkansas
And vortech
blower/new cam soon
Old 12-10-2013, 09:59 PM   #7
lemons95's Avatar
you could make a N/A split port keep up with m90, a m90 3.8 had 210hp and 315 ft lbs.
I think a modded split port could keep up and even beat it.
Maybe if you got a custom lower intake, but it would be cheaper just to get an m112 kit.(unless you know someone, or can do the work yourself) You could also bolt other blowers to the m112 intake. Any supercharger thats suppose to fit an 03/04 cobra should work.
03:37 PM
