gt gauge conversion - Mustang Evolution
Old 12-11-2013, 05:06 PM   #1
samuelsmith's Avatar
gt gauge conversion
can I put one in instead of getting a tune after I get a 8.8 rear end. P.A.T.S. is turned off
Old 12-11-2013, 05:13 PM   #2
Sorry I am not helping I was wondering about a cluster swap from a 05 into a new edge
Codyty is offline   Reply With Quote
Old 12-12-2013, 01:38 AM   #3
davidcseifert's Avatar
Region: Arkansas
Not sure what you're meant by this, assuming you mean it as change the speedo so you don't have to correct it for a gear change? The calibration is in the computer not the cluster, if you just want a 150mph speedo then it will be a straight swap into your car since the pats is turned off, but the mileage will not be the same of course.
blower/new cam soon
Old 12-12-2013, 03:11 AM   #4
DaBluedude's Avatar
Everything is possible, but realistically, the answer to your question is no. You would need to change way too much over to make it work. Including the fact the s197 cluster won't fit in the dash of an sn95
2003 Mach 1
Old 12-12-2013, 04:42 AM   #5
mummert_96v6's Avatar
Could I swap a gt gauge cluster out of a 96gt into my 96 v6?
mummert_96v6 is offline   Reply With Quote
Old 12-12-2013, 02:01 PM   #6
Yes, that is exactly what I was asking. I was afraid it was not that easy.
I can partially answer your question. You need a tuner to turn P.A.T.S. off or know the wire to cut off the fuel pump cut off switch. I am not sure if the speedometer needs to be calibrated with a tune
Old 12-12-2013, 02:47 PM   #7
2000stanguy's Avatar
Are you planning on using the GT gauges because the GT doesn't start redlining until after the v6's do.
Performance Red 2000 v6- m112 supercharger,42lb green top injectors, 310lph fuel pump, BBK shorty headers, True dual exhaust, strut tower brace, GT rear sway bar, Steeda triax short throw shifter, SR lowering springs, tinted headlights and foglights, polk audio speakers, MTX subwoofer, Kenwood head unit and black leather interior.
2000stanguy is offline   Reply With Quote
Old 12-12-2013, 03:44 PM   #8
lemons95's Avatar
Some people don't even use a tach when driving though, My grandpas ranger doesn't have it.(i'm learning to drive stick in it. He's teaching me drive by sound.)
I think the redlines kinda a recomendation, considering alot of these cars are over 100k miles. The red line is probably, off. I've never touched the red line, except for the one time at a stop sign.(friend rev his hyundai, fart cannon exhaust couldn't just stand there)
Old 12-12-2013, 05:13 PM   #9
the tach doesn't concern me mine now doesn't work anyways. And what is the P.A.T.S?
Old 12-13-2013, 09:21 PM   #10
Region: Arkansas
You have to use the tuner to correct the speedometer for gears but otherwise it's a straight swap
blower/new cam soon
Old 12-13-2013, 09:23 PM   #11
Region: Arkansas
Name:	ImageUploadedByMustang Evolution1386995001.751114.jpg
ID:	141512 I have cobra gauges in mine.
blower/new cam soon
Old 12-13-2013, 11:32 PM   #12
sam62893's Avatar
Because racecar!
Old 12-15-2013, 10:24 AM   #13
Attachment 141512 I have cobra gauges in mine.
cool, I thought it said Cobra on the gages some where or does it not glow?
Old 12-15-2013, 10:25 AM   #14
Region: Arkansas
03-04 have svt on it 99-01 don't
blower/new cam soon
Old 12-20-2013, 09:07 PM   #15
Ghostedmind's Avatar
Where the redline is on the tach doesnt matter anyway, the engine redline is controlled by the computer so its still going to redline at the same spot on the tach, i.e. ~6k, the only difference is the physical red line wont go all the way down to 6k
LCMC Member
Old 12-20-2013, 10:04 PM   #16
speedshop23's Avatar
Hey guys I wanted to do the same thing , I saw a 03 svt speedo on Craigslist for 60 bucks out of a wrecked svt and was thinking about buying it for my 02 v6 , does that mean I have to get a tuner to turn off pats? And also will I get check engine light because I'm not into that happening or I will just keep original guage ?
speedshop23 is offline   Reply With Quote
Old 12-21-2013, 01:19 PM   #17
I wish I had the cash for this........New 1999 2004 Roush Ford Mustang Speedometer Gauge Pod w Dash Bezel New RARE | eBay
what does it take to outrun a GT? austinknoll Pre-2005 V6 Mustang 72 01-14-2012 01:19 PM
my 04 gt, vs 03 cobra and 2011 mustang gt secomejia 1996-2004 Mustang GT 57 01-04-2012 08:07 AM
GT or customize my v6 xhgwx Pre-2005 V6 Mustang 37 12-23-2011 01:17 PM
FS: 2011/12 Mustang GT Strut Tower Brace Napoleon85 Mustang Parts for Sale and Wanted 0 12-22-2011 01:14 PM
04:33 AM
