4.2 swap - Mustang Evolution
Old 12-12-2013, 06:21 PM   #1
ProjectTurboV6's Avatar
4.2 swap
Still waiting for parts to come in so I'm in the process of painting. I'm curious as to who has done the swap and the problems they have ran into, as well as the solutions. I'm doing a 1998 4.2 into my 98, so I'd rather have the answer to any problem that may surface instead of guessing and wasting money on unneeded parts.
ProjectTurboV6 is offline   Reply With Quote
Old 12-12-2013, 09:00 PM   #2
lemons95's Avatar
Flex plate and harmonic balancer was all I needed.
Also the balance shaft.
I think that's it. Everything else you can reuse from the 3.8
Old 12-13-2013, 04:50 PM   #3
samuelsmith's Avatar
Also different oil pan other than that every thing is strait forward and a easy conversion
Old 12-13-2013, 05:00 PM   #4
Should I get an oil pan from a 98 f150 or will any 4.2 oil pan fit?
Old 12-13-2013, 05:05 PM   #5
lemons95's Avatar
F150 pan won't fit, you want a 01-04 mustang pan.
Old 12-13-2013, 05:07 PM   #6
The engine is out of a f150 lol
Old 12-13-2013, 05:37 PM   #7
lemons95's Avatar
Won't fit mustang body though...
Old 12-13-2013, 06:21 PM   #8
99-00 oil pan hits main bearing and 4.2 oil pan is too big for k-member
Old 12-14-2013, 08:17 AM   #9
See I didn't know that, thank you!
Old 12-25-2013, 07:05 PM   #10
lemons95's Avatar
Also, the 4.2 can is a upgrade compared to any 3.8 can. When I first drove it the torque was really noticeable it pulled a lot harder. Never ran it before, a stock v6 auto is suppose to run 17.5, I was running 16.7's and my reaction time was usually .3. So if I got the reaction down, id be running a 16.4 if I got it timed perfectly.
Sent from my LG-MS770 using Mustang Evolution mobile app
---------- Post added at 09:05 PM ---------- Previous post was at 09:03 PM ----------
I can't edit on my phone but to avoid confusion, Its the whole engine not just the can that made the difference, my post made it sound like it was just the cam...
Old 12-27-2013, 09:21 PM   #11
Ghostedmind's Avatar
My understanding is that your track time is not effected by your reaction time. I.E. Your 16.7 would have been 16.7 regardless of what your reaction time is.
---------- Post added at 12:21 AM ---------- Previous post was at 12:20 AM ----------
Also, from what I remember doing research about the cams, the 4.2 cam is more for lower end torque and i belive has a shorter powerband vs the 3.8, the 3.8 cam will give you more in the higher end
LCMC Member
Old 12-27-2013, 09:40 PM   #12
With that said, I'm getting the 4.2 cam reground. I'm high compression 4.2 would work better with mire high end power, correct?? So say 110-112lsa???
Old 12-28-2013, 03:23 PM   #13
lemons95's Avatar
Dont know where your racing at but at most tracks the timer starts when the light goes green, not when the driver gets off the line. I have a .3 reaction between when the light turn s green and when I mash my foot on the gas. So if I got the reaction close to perfect, like .006 I'd be running the 16.5's.
---------- Post added at 05:19 PM ---------- Previous post was at 05:17 PM ----------
I think most high rpm cams are made with lower LSA.
If you get a performance cam, you would notice a bigger gain if you also ported the heads and intake.
---------- Post added at 05:21 PM ---------- Previous post was at 05:19 PM ----------
Fing phone double posted.
---------- Post added at 05:23 PM ---------- Previous post was at 05:21 PM ----------
The 4.2 cam from what I remember makes more power in any of the engines, 4.2 or 3.8. The 3.8 cams are just weak. 4.2 needed to make power, so its a little more beefy than the 3.8 cams.
Old 12-28-2013, 04:18 PM   #14
The cams
Originally Posted by someone on another site
99-up 3.8L
.423/.447 246/262 116 LCA 26 deg overlap
97-up 4.2L
.424/.447 252/270 110 LCA 32 deg overlap
I did some other modeling using the 4.2 cam in a 3.8L = some nice gains. About 5 ft/lbs of torque all through the mid-range and at least 12 HP. Thats a pretty good gain that could get you a couple of tenths in the 1/4 for no $$$. Some of these guys building 4.2s have the stock cams leftover...could be a real cheap alternative to a custom cam
So you're right, the 4.2 cam does add a little more.
LCMC Member
Old 12-28-2013, 04:47 PM   #15
I get this from a more accurate sight.
Check the factory cam specks, he is all wrong.
99-03 3.8L XR3Z-6250-CA
178/194 .427/.446 116LCA 111ICL
97-04 4.2L
185/194 .443/.445 112LCA 110ICL
Chad quote:
Edit: 97-04 4.2 uses same cam. 99-03 3.8 uses same cam.
Camshaft specifications - V6Power MessageboardwHICH CAM IS WRIGHT? I do not know. Could they be different? I find inaccurate information on the web all the time.
I would not trust anyone who says the gain from a 4.2 cam is 5hp and 12tq. THE TOTAL GAIN FROM A FACTORY STROKED 4.2 is 5hp. and 15tq. Do you want to tell me a cam did all that? The best cam gain from SSMS which is a copy of the Comp Cam is 15 hp.
Personally a windstar intake swap is better.
1 you do not need a tune
2 the price is lower
3 more hp (7 hp+15 tq)
4 easier for beginners to learn
5 unless you port n polish and cam a 4.2 the gains are not valuable dollar for dollar
jUST TRYING TO KEEP THE SIGHT ACURATE
Old 12-29-2013, 11:23 AM   #16
Not sure where your racing, but that's not how it works anywhere. The timer doesn't start until you start moving
87fiveoh is offline   Reply With Quote
Old 12-29-2013, 11:43 AM   #17
+1
BTW Lemon, I don't know from experience, I was told that by a co-worker of mine while I was in the military who had been racing Pro-mod, Funny, Rail and other classes for over 15-20 years.
LCMC Member
Old 12-29-2013, 12:08 PM   #18
lemons95's Avatar
I'm going off of what I was told, its why a lot of drivers here try and get double zeroes in the reaction time.
Otherwise it would be mostly car against car, not driver against driver. Most of the pros around here use built auto trannies.
Old 12-29-2013, 12:20 PM   #19
lemons95's Avatar
Or are you talking about bracket racing, I googled it. That one the timer starts after the driver moves.
We have that here, but not for the street legal days, just on the competitions. So I've never raced that way.
Old 12-29-2013, 06:40 PM   #20
davidcseifert's Avatar
Region: Arkansas
4.2 swap
No matter what type of racing you do the reaction time is not counted in the ET. Stock for stock the 4.2 cam is better but it's a small change of course. Tighter lsa tends to lower peak power a small amount, not tremendously.
blower/new cam soon
03:32 AM
