96 v6 wanting to swap to 351w - Mustang Evolution
Old 12-13-2013, 11:37 PM   #1
ok so I have a stock 96 v6 t5 tranny 8.8 rear. what all do I need to do to the car to get a 351w to run. Im wanting it carburated I know I have to get new fuel pump but what else do I need to upgrade?
shon08 is offline   Reply With Quote
Old 12-14-2013, 12:06 AM   #2
irishn8's Avatar
Ur tranni wont work, u need one from a v8. You dont really have to get a new pump, u can just get a fuel pressure regulator, either way works though.
Also i believe you will want to beef up the front suspension for the heavier engine.
Old 12-14-2013, 12:28 AM   #3
I was planning on running fuel cell cause the current take leaks gas out of fuel neck when you go around a right turn and could lowering springs for gt work?
Old 12-14-2013, 12:36 AM   #4
irishn8's Avatar
Oh ok.
Lowering springs, maybe, i think they should be thicker though. I really dont know much about suspension. I remember reading an article about swapping a v6 for a v8 in a 65 mustang so im not sure if that applies to u.
Old 12-14-2013, 01:05 PM   #5
ok should I beef up the chassis since the 351 will have a lot more power or should it be ok since its the same frame and sub frame as gt just smaller motor?
Old 12-14-2013, 02:05 PM   #6
Robbiemustang96's Avatar
What about the K member? If its a 96 then wasnt the k member modified to allow for the 4.6? Or will the stock K member work with the Motor mounts? Cause i remember seeing somewhere that the V6 mounts are the same as a 302 or 351.
Robbiemustang96 is offline   Reply With Quote
01:05 PM
