95 3.8 theft light flashing starter wont turn over. - Mustang Evolution
Old 12-14-2013, 12:38 PM   #1
hi, ive been having an intermittent starting issue with my mustang. its a 95 3.8 5 spd. randomly the starter wont crank and the theft light on the dash keeps flashing. sometimes the starter will click but wont turn over. i have checked the battery and connections and im on my 3rd starter since june. it acts like the starter is bad. we are able to push start the car and it runs fine sometimes when you shut it off after push starting it will start again. but today it wont start on its own at all. ive tried disconnecting the battery as well with no luck. anyone know what might be going on? pats system? wiring issue? nothing modified on the car other than an aftermarket coolant gauge...
hhrt1234 is offline   Reply With Quote
Old 12-14-2013, 01:40 PM   #2
samuelsmith's Avatar
check battery terminals
Old 12-15-2013, 01:36 PM   #3
Project Pony's Avatar
I had a similar issue when my computer died. New computer and pats reprogrammed and she started right up. Is it showing any DTC codes?
[SIGPIC][/SIGPIC]
Old 12-18-2014, 07:26 PM   #4
i have 99 3.8 that cranks but wont start and the security light flashes any ideas
peetey is offline   Reply With Quote
Old 12-18-2014, 08:23 PM   #5
baddbradd's Avatar
IMO, it sounds like a security, KEY, chip issue...pats
2001 coupe
baddbradd is offline   Reply With Quote
Old 12-19-2014, 03:20 PM   #6
one mechanic said it was fuel pump replaced started ran rough then wouldnt restart second mechanic said it was crmm and replaced with used one ran a lil rough on restart no start , not sure now cant read codes so some say possible ecm ? so $350.00 in parts and labor no runnin yet we did try second set of keys still nothing how do u check the pats and what else can we do ? the cant read code issue is kinda head spinning thanks
09:51 AM
