stillll overheating with new.... - Mustang Evolution
Old 12-14-2013, 01:14 PM   #1
ok so ive changed the water pump, changed the coolent, and today i just changed the thermostat and its stillll overheating, could there be air in the system?? if so can someone give me a good detailed description how to get the air out?? ive never had to bleed air out of the radiator system before , thanks guys! it wouldnt be a head gasket would it? theres no white smoke coming out of the tailpipes and no water/antifreeze in the oil so i wouldnt think it could be a head gasket
wootman101 is offline   Reply With Quote
Old 12-14-2013, 01:29 PM   #2
sebasflorez's Avatar
Here you go:
http://www.allfordmustangs.com/forum...8-mustang.html
sebasflorez is offline   Reply With Quote
Old 12-14-2013, 01:39 PM   #3
samuelsmith's Avatar
LOok above the water pump across from the egr the metal pipe that has several hoses running to it. There is a piece you can loosen at the top of it to bleed air.
Old 12-14-2013, 01:43 PM   #4
sweet! thanks man!
Old 12-14-2013, 03:53 PM   #5
ok guys i got it bled and no more overheating!!! thanks!!!
07:24 AM
