whyyy, stilllll overheating!! anymore ideas? - Mustang Evolution
Old 12-17-2013, 10:24 AM   #1
ok so ive bled the cooling system like, 12 times, she ran fine for about 30 mins then overheated again, i let her cool down and bled the lines again, but now she stilllll overheats driving short distances! once i get on the highway about 60-65 she cools back down! could there be another pressure valve somewhere i need to bleed?? any suggestions would help!
wootman101 is offline   Reply With Quote
Old 12-17-2013, 10:28 AM   #2
03Graymach's Avatar
are you fans coming on cause it sounds like your not getting enough wind though the engine bay to move out to hot air
03Graymach is offline   Reply With Quote
Old 12-17-2013, 10:41 AM   #3
JimmyMosqueda's Avatar
Get rid of your hood. Boom. Next problem!
JimmyMosqueda is offline   Reply With Quote
Old 12-17-2013, 10:43 AM   #4
ya the fan kicks on good, i just noticed the hose that goes from the bottom driver side of the radiator is stiff as hell though, i dont think its supposed to be hard?
Old 12-17-2013, 10:43 AM   #5
mystang50's Avatar
x2!!
Old 12-17-2013, 10:44 AM   #6
bucko's Avatar
Yep, check the e-fans for proper operation. Idling in the driveway, they should kick on when the temp gets to halfway.
Old 12-17-2013, 10:46 AM   #7
haha ya im bout to just get rid of the whole damn thing!
---------- Post added at 11:46 AM ---------- Previous post was at 11:44 AM ----------
like whenever i bleed the system, the heat works great in the car for about 10 mins then it gets cold again and the car starts overheating again, then i have to let it cool down and bleed it again, i know someone said there could be more than on pressure valve but the only one i know of is right above the water pump
Old 12-17-2013, 11:04 AM   #8
mystang50's Avatar
have you checked your t-stat? could be gunked up with trash or something that keeps getting recirculated? or could be on backwards.
---------- Post added at 12:04 PM ---------- Previous post was at 12:02 PM ----------
what about the pump? could be eroded from tap water.
Old 12-17-2013, 11:11 AM   #9
03Graymach's Avatar
haha ya im bout to just get rid of the whole damn thing! ---------- Post added at 11:46 AM ---------- Previous post was at 11:44 AM ---------- like whenever i bleed the system, the heat works great in the car for about 10 mins then it gets cold again and the car starts overheating again, then i have to let it cool down and bleed it again, i know someone said there could be more than on pressure valve but the only one i know of is right above the water pump
Should be another on near the thermostat
Old 12-17-2013, 11:20 AM   #10
ok guys thanks, i just remembered someone said to jack up the front end and thennn bleed it, i havent tried that either, i think she might have to wait til it warms up a bit though its been under 30 degrees alllll freakin week. gonna try to push her into the garage and see what i can do
Old 12-18-2013, 01:07 AM   #11
davidcseifert's Avatar
Region: Arkansas
How are you bleeding it... You shouldn't have to jack it up if you're doing the procedure right
blower/new cam soon
09:49 AM
