Is it my idle Air Control Valve? - Mustang Evolution
Old 12-18-2013, 11:56 AM   #1
Sluder4's Avatar
Recently everytime I crank my 1999 v6 it does this weird rumbling noise and my RPMs just jump up and down really quickly. Its like its a really bad idle. Its of course only when its in idle as well. But my check engine light doesnt come on tho. Just wondering if this could be what it is. Thanks!!!
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 12-18-2013, 01:30 PM   #2
From what you just described, I would say yes, your IAC is probably worn out...
Old 12-18-2013, 02:20 PM   #3
irishn8's Avatar
Theres actually quite a list of things that can cause that but yes, most likely its ur IAC
+1 on that
Old 12-18-2013, 09:51 PM   #4
Sluder4's Avatar
Thanks y'all! Hopefully thats what it is because its a really simple fix if so and a cheap part (compared to others). How would I check to make sure thats what it really is? Just unhook it and start up the engine and if it runs smooth then thats it?
Old 12-18-2013, 10:18 PM   #5
Disconnect the negative battery cable before you get started. When you get finshed let the engine idle for about 15 minutes so the ECU can relearn the idle. That's it!
Old 12-18-2013, 11:43 PM   #6
Sluder4's Avatar
Okay sounds good! Will try this out in the morning and see what happens.
Old 12-27-2013, 10:54 AM   #7
RaysV6's Avatar
Send a message via Yahoo to RaysV6
I thought it was mine as well, took it to a shop not only will an iacv go out but also the upper and lower intake manifold gaskets. Which mine need to be replaced before i can put a tune on it.
RaysV6 is offline   Reply With Quote
03:18 PM
