Help - Mustang Evolution
Old 12-20-2013, 10:58 AM   #1
Streetstangmigg's Avatar
Region: Arkansas
Help
Hi guys new this actually i had a diff profile
But forgot my info so made a new one
Anyway i need some help my car wont rev past 4rpms
When its in neutral i know thats not normal bc its never done that before
And it does the same when i try to gun it idk what it could be
She drives and shifts good and theres no signs of any oil leak
So if anyone has a solution i would greatly appreciate it
Thanks
Streetstangmigg is offline   Reply With Quote
Old 12-20-2013, 11:49 AM   #2
Mine won't rev past 4k rpms either maybe yours has a rev limiter on it?
Codyty is offline   Reply With Quote
Old 12-20-2013, 11:52 AM   #3
Region: Arkansas
I dont think its that i used to redline it on the road and now when i try it wont go past 4rpms it does the same when in neutral
Old 12-20-2013, 08:00 PM   #4
Ghostedmind's Avatar
Do you have a bama tuner that you use on it?
LCMC Member
Old 12-20-2013, 10:10 PM   #5
Region: Arkansas
No
Old 12-21-2013, 03:04 AM   #6
mine just started doing the same, mines from a small pinhole leak, check where the water pump connects to the block, on the underside of the block, my car overheats now too because of it, still trying to figure out a way to fix it
wootman101 is offline   Reply With Quote
Old 12-23-2013, 09:40 AM   #7
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Thanks
This sounds very odd. It's definitely time for some maintenance. I would recommend checking the Spark Plugs, Wires, Vacuum Lines etc.. It may not be a bad idea to run it past the Dealership just to see what could possibly be going on!
Best of luck locating the issue. Let us know if we can be of any assistance!
-Dan
08:37 AM
