8.8 Rear end swap. - Mustang Evolution
Old 12-21-2013, 09:43 PM   #1
Region: South Dakota
8.8 Rear end swap.
I'm really sorry guys I'm sure this has been asked plenty of times but everywhere I look its a different answer.
I have a 1998 V6, can I swap just the 8.8 differential into my axle housing? Or do I need to buy the whole GT housing?
If I can do the swap my axle shafts are 28 spline correct?
Just differentials are only a couple hundred bucks used and I can have shipped to me along with the gears I want, and none of the salvage yards close to me have one and I'd hate to pay freight on an entire axle housing.
zhill29 is offline   Reply With Quote
Old 12-22-2013, 01:05 AM   #2
lemons95's Avatar
You need the whole 8.8 rearend, bolts in with no modifications...
a 94-04 rearend would work, I use a 2001 GT rear end under my 1995 V6. I think it's about half and inch wider? everything still bolted up with no problems though.
It'll be hard to find one with the gears you want, I don't know about 94-98 GT's but the 2001 I got had 3.27's stock, better than the stock 2.73's.
Old 12-22-2013, 07:47 AM   #3
Now by whole rear end your talking the axle housing correct? From wheel to wheel with axle shafts and all?
And I'm not worried about the gear ratio, I will just buy a set of my choosing from Summit racing, they are only like $200 and then I can pick exactly what I want. Hell I'll probably buy 2 sets so I can maintain decent mileage and switch to the go fast gears when I want to.
Old 12-22-2013, 08:38 AM   #4
The entire housing is different.
Also, gears are not just a bolt and go thing, they must be setup correctly with shims and spacers to prevent noise and wear.
Old 12-22-2013, 10:01 AM   #5
samuelsmith's Avatar
94 forward is the 31 spine axle and it is about 30% stronger than the previous 28 spine axle. We have v-6s so the extra spines will not matter. Pre 94 8.8s fit just shorter
Old 12-22-2013, 12:30 PM   #6
Ok, but for the record I'm doing the V8 swap next winter, I bought the car wrecked so I'm just going to get it road ready for this summer then build my engine for it this summer to put in next winter. Along with the 8.8 and everything else I'm getting. I'm just going to head out to a salvage yard and find a couple GT's and start yanking parts off.
Old 12-22-2013, 01:38 PM   #7
lemons95's Avatar
Pre-94's are also 4 lugs though. Would have to convert to 5 look lug.
Sent from my LG-MS770 using Mustang Evolution mobile app
Old 12-22-2013, 06:42 PM   #8
Yea, you have to go to a 5 lug axle and the axle bearing should be changed due to the age. I personally would not go any deeper because rear end rebuilds are for the pros. A engine is easy but rear ends are a whole new story. It's like doing surgery and everything must be perfect.
Old 12-22-2013, 10:49 PM   #9
Nope. All 94-04 GT 8.8's are 28 spline. You'll need a 94-98 Cobra, 01 Bullitt or 03/04 Mach rear for 31 spline axles.
Old 12-23-2013, 01:28 PM   #10
The Ford 8.8 Mustang Rear End - Car Craft Magazine
Old 12-24-2013, 08:29 AM   #11
Sorry but that article is wrong...i've torn down quite a few gt rears and have yet to find 31 spline axles.
Old 12-24-2013, 10:08 AM   #12
sebasflorez's Avatar
You would be correct. A buddy of mine switched his stock 28 spline axles to a brand new set of 31 spline axles on his 01 GT, so yeah 94-04 have 28 stock.
sebasflorez is offline   Reply With Quote
Old 12-24-2013, 11:35 PM   #13
baddbradd's Avatar
ditto on the 28 spline. The full size trucks with an 8.8 are 31 spline
2001 coupe
baddbradd is offline   Reply With Quote
Old 12-25-2013, 01:39 PM   #14
I read the article a long time ago and personally do not have any experence with the 8.8.
It wont be the first time a magazine got something wrong.
Old 12-25-2013, 04:41 PM   #15
Torchredfrankie's Avatar
05 and up GTs have 31
Torchredfrankie is offline   Reply With Quote
Old 12-25-2013, 06:33 PM   #16
No problem man. Just want to make sure the right information is out there.
Old 12-25-2013, 06:48 PM   #17
Milehigh STK's Avatar
What price should I go for on this?
also have a rear axle removed from 2004 mustang GT. it has factory 3.27 gears and factory posi, and was removed in good working condition to install new geared axle. looking for 350.00 or best offer.
Milehigh STK is offline   Reply With Quote
Old 12-26-2013, 02:59 PM   #18
lemons95's Avatar
I think it would depend how many miles are on it.
Old 12-26-2013, 03:00 PM   #19
40k miles
Old 12-26-2013, 03:00 PM   #20
lemons95's Avatar
And for $350 it better be low mileage.
Old 12-26-2013, 03:00 PM   #21
Talked him to 300
Old 12-26-2013, 03:01 PM   #22
lemons95's Avatar
Fast reply lol, $350 is probably. Wouldn't hurt to try and talk him down lower though.
Old 12-26-2013, 03:02 PM   #23
He said he would do 300 I might get 275 out of him
Old 12-27-2013, 09:18 PM   #24
Ghostedmind's Avatar
Is the drive axel the same length as the 7.5 rear?
LCMC Member
Old 12-30-2013, 09:10 PM   #25
Yes, the axles are the same.
Old 01-08-2014, 10:22 AM   #26
How big of a difference will I feel with the limited slip differential and 3.73 gears?
Old 01-08-2014, 11:54 AM   #27
People who get 373 always wish they got 410s. search it in the v-8 section.
Old 01-08-2014, 07:22 PM   #28
4.10 are bad ***! Anything lower and you'll be cheating yourself.
CoolHorsey is offline   Reply With Quote
Old 01-08-2014, 07:35 PM   #29
What Roma are you guys hitting on the highway?
---------- Post added at 08:35 PM ---------- Previous post was at 08:34 PM ----------
RPMs sorry and on a v6
Old 01-08-2014, 07:43 PM   #30
I don't have a v6 by I'm almost certain a gear change is like waaayyyy more fun on a v6 than a v8
Old 01-08-2014, 07:45 PM   #31
I'm sure it is but I don't want to be running 4k RPM at 65
Old 01-08-2014, 08:00 PM   #32
This video should give you a pretty good idea of how a new edge v6 with 4.10s will spin
Fwiw, my gt spins around 2.5k @ 65. But its an auto. 5 speeds rev lower because they have that extra gear
Old 01-08-2014, 08:05 PM   #33
I know I'd love it in city but highway is what I'm concerned about. I'll look for some real numbers
Old 01-08-2014, 08:07 PM   #34
Oooh I see. Get the 3.73. That's the gear you get when MPG comes into play. But from what I've read its not THAT much of a difference.
As far as the actual swap, I can't help you there because idk. Sorry friend
Old 01-08-2014, 08:08 PM   #35
It's alright. Thanks for the help!
07:05 PM
