Wheel alignment help - Mustang Evolution
Old 12-23-2013, 12:11 PM   #1
Ghostedmind's Avatar
My wife recently hydroplaned and hit a curb with the front left end. The top of the tire now points more outward than it should, and is pushed back more in the wheel well than it should, the guy said more than likely I bent the front LCA, .....I can't tell whether or not its true, and I need to because I don't have the spare money to throw at parts hoping its the answer..... help?
Sent from my DROID RAZR HD using Mustang Evolution mobile app
LCMC Member
Old 12-23-2013, 12:22 PM   #2
The passenger side is fine, the steering wheel is straight in both of these pictures
ID:	142640   Click image for larger version
ID:	142642   Click image for larger version
LCMC Member
Old 12-23-2013, 12:40 PM   #3
OUCH!
Yep. Probably the control arm. Hopefully thats all...
Check Rockauto.com. They may have the lower control arm, complete with ball joints and bushings already installed.
Old 12-23-2013, 02:15 PM   #4
RaysV6's Avatar
Send a message via Yahoo to RaysV6
+1^ i work at a body shop and seen that on a subie forester, lca needed replaced, most likely i would check ur local junk yard and fined yourself a used one for the time being. Definately your lca also check ur sway bar end link as well.
RaysV6 is offline   Reply With Quote
Old 12-23-2013, 03:22 PM   #5
Ok, now, I know a good bit about the engine side of things, but not much about the suspension side. Are the LCA and the A arm the same thing?
LCMC Member
Old 12-23-2013, 04:13 PM   #6
RaysV6's Avatar
Yes lower control arm is jus another name depending on who your talking to.
Old 12-23-2013, 04:19 PM   #7
DAmn.....lol
LCMC Member
Old 12-23-2013, 07:34 PM   #8
Well, hopefully my local pull-a-part has one. If all they have is a GT, is the front LCA off a GT interchangable with one off a V6?
LCMC Member
Old 12-23-2013, 07:39 PM   #9
RaysV6's Avatar
I would think so but not too sure off the top of my head. Maybe 1slosix chimes in, he may know whats interchangeable between 6 and 8
Old 12-28-2013, 11:56 PM   #10
lemons95's Avatar
I don't see why it would be different, might be a bit for beefier.
Sent from my LG-MS770 using Mustang Evolution mobile app
Old 12-29-2013, 12:00 AM   #11
They're the same on all New edges.
Old 12-29-2013, 12:50 AM   #12
Good, thanks
Sent from my mobile device.
LCMC Member
09:52 AM
