4.2 swap - Mustang Evolution
Old 12-26-2013, 10:56 PM   #1
4.2 swap
If anyone has alot of knowledge about these swaps and can answer me a few questions and it wouldn't take to much of your time can you message me thanks and god bless
Codyty is offline   Reply With Quote
Old 12-27-2013, 11:41 AM   #2
sebasflorez's Avatar
There's a sticky on here with all the info you need on that.
sebasflorez is offline   Reply With Quote
Old 12-27-2013, 12:03 PM   #3
I read it but I have a few more questions
Old 12-27-2013, 01:33 PM   #4
samuelsmith's Avatar
Just ask, it is common knowledge because the questions have been asked soooooooooooooooooooooooooooo many times. IT'S JUST A STROKED 3.8 with +5 hp. and 15 tq. You also need a tune
Old 12-27-2013, 02:53 PM   #5
How much will parts run me for the whole build if I use my stock block and heads does it use the 3.8 Trans and can I drive it for awhile without a tune
Old 12-27-2013, 03:09 PM   #6
The 4.2 is just a stroked 3.8 so externally it is the same. The transmission will mount because the engine has the same bolt holes as the 3.8.
The price depends on your shopping places. The heads will work, but the bottom of the engine is different. You would need a new crank, rods, and pistons. Most people get a junk yard engine to save the money that the rods and crank will cost. I herd somewhere you can not put 4.2 internals in a 3.8 but am not personally sure.
It will crank without a tune and you will wish you never cranked the engine because it will run like crap. David sells tunes for the 4.2. AM does not.
Old 12-27-2013, 03:14 PM   #7
Ok so if I get a junkyard engine out of a wrecked f150 just clean it up and everything should bolt up fine? And any idea on how much his tunes are?
Old 12-27-2013, 03:29 PM   #8
Do you have a tuner?
Old 12-27-2013, 03:33 PM   #9
No
Old 12-27-2013, 03:40 PM   #10
No
pm davidcseifert he will give you a estimate. You should do some port n polish work to the heads and intake to get a decent amount of hp. gain.
Old 12-27-2013, 03:45 PM   #11
Not to sound stupid but could any mechanic do that
Old 12-27-2013, 03:50 PM   #12
port n polish pony power
David and I explained how to do it. I can go into deeper detail
Old 12-27-2013, 03:56 PM   #13
Thank you for all your help if this worth doing for the price in your opinion?
Old 12-27-2013, 04:23 PM   #14
Not unless you are getting it ported and polished. If you are paying a mechanic to rebuild the engine I can tell you where to get the cheapest 4.2 that is ported and polished.
Old 12-27-2013, 04:31 PM   #15
Mind if I pm you?
Old 12-27-2013, 04:33 PM   #16
Mind if I pm you?
Cool, I need to erase some pms. The in box fills up fast
Old 12-27-2013, 11:07 PM   #17
ProjectTurboV6's Avatar
I'm doing the swap right now, so I can help with an estimate on how much it will possibly cost..
ProjectTurboV6 is offline   Reply With Quote
Old 12-27-2013, 11:27 PM   #18
I sent you a pm
Old 12-27-2013, 11:28 PM   #19
I sent you a pm
Your pm box is full...
Old 12-27-2013, 11:33 PM   #20
Sorry I deleted some
Old 12-28-2013, 11:51 PM   #21
lemons95's Avatar
It will run without a tune, mine runs a little lean. I've been driving it for more than year. If I had a tuner and egr tube I'd be pretty happy though.
Sent from my LG-MS770 using Mustang Evolution mobile app
Old 12-29-2013, 06:49 PM   #22
davidcseifert's Avatar
Region: Arkansas
Price, depends on what deals you find, I bought an entire 66K miles 4.2 for $300.
blower/new cam soon
05:27 PM
