M112 need help - Mustang Evolution
Old 01-01-2014, 12:04 AM   #1
speedshop23's Avatar
M112 need help
Ok so I am In the process of supercharging my 02 3.8 , can anyone help send me a build link or something like a list for the parts I will need, I have found threads before for the m112 setup when doing previous research but I don't know if I'm having a bad day today or I just can't find any lists, thanks
speedshop23 is offline   Reply With Quote
Old 01-01-2014, 02:39 PM   #2
samuelsmith's Avatar
99-04 M112 Supercharger Installation - MustangForums.com
Old 01-01-2014, 04:05 PM   #3
Thanks
Old 01-02-2014, 12:44 AM   #4
Originally Posted by speedshop23 View Post
Thanks
YW M112 4 $300
eaton m112 supercharger
Old 01-02-2014, 06:05 AM   #5
Thanks but I already have the supercharger itself
Old 01-08-2014, 01:08 PM   #6
David has a friend who is working on a cooler to sole the heat problem. You should contact him.
Old 01-08-2014, 01:12 PM   #7
Do the m112"s really have that bad of a heat problem
Old 01-08-2014, 04:39 PM   #8
I think the issue is in the south because of hotter temperatures. I am sure it is bad because that is all that is stopping him from installing his M112
Old 01-08-2014, 05:16 PM   #9
But is it like bad enough where it like melts wiring or vacuum lines type thing or can it like screw up the good from the heat
Old 01-09-2014, 04:05 PM   #10
The issue may have been he is using a cam and the extra boost causes heat issues. The problem was engine over heat. If David sees the post he should solve my guess work.
Old 01-09-2014, 07:27 PM   #11
Yeah I only got a stock cam for now , planning on finishing supercharger in spring because I don't want to go hood less in the snow
Old 01-10-2014, 01:15 AM   #12
davidcseifert's Avatar
Region: Arkansas
Non-intercooled M112 setups make large amounts of heat.. Intake temps over 200* on 12psi+ which will quickly degrade a motor. Ported blower and intake/heads help to reduce heat as it reduces the restriction. A quick way around the heat is a meth kit, which will drastically reduce iat's, but like nitrous, you become slow when it runs out lol.
As for the kit Luis and I are setting up, it's being delayed by money problems on my end, and fabrication from our welder being out of town frequently (truck driver).
blower/new cam soon
Old 01-10-2014, 02:01 PM   #13
You can put a GT scoop on it, but the pulley will still stick out. I don't know how you are doing financially. The Cobra R hoods are on Ebay for $400 shipped. My Cobra R carbon fiber hood was tearing up, so I jumped on this deal a year ago.
Old 01-10-2014, 02:25 PM   #14
I like the 3 inch cowl hoods I found one on V6mustang for cheap but waiting on seller to confirm the color he has
---------- Post added at 09:25 PM ---------- Previous post was at 09:23 PM ----------
If it all comes down to it and can't get a good priced used hood , gt scoop is going to be my route
Old 01-10-2014, 02:49 PM   #15
I was never good at sculpting so I never tried this. You can measure the length, height, and with need to cover the M112. Take a block of starphone and start sculpting a scoop upside down. Make sure you get all the angles right. Cover with a brush in fiberglass. When it dries cut fiberglass cloth and do 7 more layers. Pressing the cloth with fiberglass resin using a paint roller.
After it dries remove straphone and place on hood. Now grind the bottom with a sander till the hood scoop is flush with the hood. This takes much patients. Start from one corner of one side and work to the other.
Now sculpt a piece of straphone to fit in the corner edges and stick out flat a inch. You are making a flat bottom so it will bolt up. Repeat previous instructions with 7 lavers of fiberglass. When dry put on hood to make sure it is flush. Drill two bolt holes on each side. Remove scoop and run a light coat of bondo on top and sides. Sand, paint, and install.
This is hard, and how to make a custom scoop.
This is kina how to do it...................make a custom scoop - Bing Videos
Old 01-11-2014, 12:09 AM   #16
Sounds extensive
Old 01-11-2014, 02:21 AM   #17
ProjectTurboV6's Avatar
What kind of gains can you see from the m112 compared to say a Garrett Pt61??
ProjectTurboV6 is offline   Reply With Quote
Old 01-12-2014, 03:28 PM   #18
That is close to how they are mode from the factory except, the factory has a mold and does not need Bondo.
Old 01-12-2014, 03:41 PM   #19
Id rather buy the scoop lol much easier for me , not a very good painter
Old 01-16-2014, 03:26 PM   #20
Region: Arkansas
I've been looking at rivet on hood scoops for my project, looks nice and gives me the clearance I want, just gonna cut a big hole in stock hood.
blower/new cam soon
08:17 PM
