5.4l lightning svt motor swap? - Mustang Evolution
Old 01-07-2014, 12:57 PM   #1
HellRaiser's Avatar
I have the v6 now, but I am just not happy with the power coming from it. I heard that you can do a 5.4l swap into it but how hard is that to do?
HellRaiser is offline   Reply With Quote
Old 01-07-2014, 01:09 PM   #2
You can swap anything with enough money but if you plan on swapping a lighting with the supercharger plan on either living without a hood or about a 8 inch cowl
Codyty is offline   Reply With Quote
Old 01-07-2014, 04:15 PM   #3
samuelsmith's Avatar
You should post this in the v-8 section. Learn everything you need to swap and then come back here to find out how many more credit cards you need to max out. There use to be a cd on Ebay for the swap, but it has gone underground.
Old 01-07-2014, 09:42 PM   #4
HellRaiser's Avatar
Hey thanks for the input, is there any cheap mods to bring out more power?
Old 01-07-2014, 10:28 PM   #5
Screaming Mach's Avatar
This is a 5.4 swapped it would look like a beast but its not cheap to do.Click image for larger version
Name:	ImageUploadedByMustang Evolution1389155327.157265.jpg
Screaming Mach is offline   Reply With Quote
Old 01-08-2014, 12:57 PM   #6
PONY POWER!
svt
08:54 AM
