3.8 v6 to 4.6 swap (info needed) - Mustang Evolution
Old 01-09-2014, 04:56 AM   #1
Veracadoro's Avatar
Hello, I am considering swapping my v6 engine out for the v8 of the same year and was wondering what all I would need to purchase with the engine to do this swap. (I am new to swaps)
Veracadoro is offline   Reply With Quote
Old 01-09-2014, 05:41 AM   #2
TaylorF25's Avatar
If you can get a complete donor car, then that would be the bet way to go.
---------- Post added at 12:41 PM ---------- Previous post was at 12:40 PM ----------
Best*
TaylorF25 is offline   Reply With Quote
Old 01-09-2014, 07:46 AM   #3
Veracadoro's Avatar
Oh, well I mean is there an easy way to get like a parts list or something? I'm more or less trying to make sure that when I'm doing it I don't find myself missing anything
Old 01-09-2014, 09:03 AM   #4
Mustang81596's Avatar
Like Taylor said, get a donor car. Or better yet, it would be cheaper to just sell your sixxer and buy a gt. If you're stuck on the swap, it's going to expensive fast. It isn't just the engine. You need the rear end, suspension, trans, etc. most people who start the swap don't end up finishing it
pypes x w/flow 40's, SR CAI, plasti dipped (emblems, stripe, rear decklid, rear valance, cowl vent grille, fuel door, antenna holder), shorty antenna, mach 1 chin spoiler, custom interior trim, blue LED interior lights, more to come later
Mustang81596 is offline   Reply With Quote
Old 01-09-2014, 09:06 AM   #5
Veracadoro's Avatar
Okay, yeah he main reason I was looking on the direction of the swap is I really like the body of the car I'm driving a lot of custom body work and audio/video work has been put into it
Old 01-09-2014, 10:32 AM   #6
I am in the same boat you are I got about 6k in the appearance of my sixxer but I hate the hp of it ever think about going with a 4.2 swap?
Codyty is offline   Reply With Quote
Old 01-09-2014, 10:34 AM   #7
Veracadoro's Avatar
Well I was looking at the 4.6 because I plan on putting a twin turbo into it and the turbo I found was made for the 4.6
---------- Post added at 01:34 PM ---------- Previous post was at 01:33 PM ----------
Originally I wanted to just bore it out to a 4.0
Old 01-09-2014, 10:35 AM   #8
You could procharge or use an m112 off a cobra. The m112 is one of the cheapest ways to go
Old 01-09-2014, 10:38 AM   #9
Veracadoro's Avatar
I guess, I've been kinda stuck on the turbo ideA.
Old 01-09-2014, 10:40 AM   #10
There are no 3.8 turbo set ups. Perhaps you could piece a kit together yourself and have a shop fabricate up manifolds. Be prepared to pay a hella lot is you go that route.
Old 01-09-2014, 10:53 AM   #11
Veracadoro's Avatar
Well that was why I was asking about the 4.6 swap
Old 01-09-2014, 11:02 AM   #12
How much're you lookin to spend
Old 01-09-2014, 11:10 AM   #13
Veracadoro's Avatar
I really don't have a limit, just the more I need to spend the longer it will take
Old 01-09-2014, 11:34 AM   #14
Veracadoro's Avatar
Old 01-09-2014, 11:38 AM   #15
TorchRed6's Avatar
well im by no means a pro but from what i can think of:
all new suspension- youve gotta be able to handle the weight of a new motor
8.8 rear end- you'll snap that little 7.5 in no time
might as well get a quality 1 piece driveshaft while your at it
new transmission
obviously a 4.6 engine
if you plan on a TT setup then you might as well forge the 4.6
all new engine accesssorys- alternator, starter, that junk.
new fuel pump since you'll be pushing more fuel
i would assume(note that word) that you would need a new ECU
new wiring harnesses
bigger radiator
completely upgrade your brake system
thats all i can immediately think of. so your gonna be in the 10-15 grand area. easily.
TorchRed6 is offline   Reply With Quote
Old 01-09-2014, 11:40 AM   #16
Veracadoro's Avatar
Thank you, I was actually just about to replace the whole brake system with the slotted drilled like in the mach 1
Old 01-09-2014, 11:45 AM   #17
TorchRed6's Avatar
thats really a track application. not that great for the streets. i mean it looks cool, yeah. but im pretty sure you actually lose stopping power in exchange for them running cooler. make sure you get some big brakes too.
Old 01-09-2014, 11:46 AM   #18
Veracadoro's Avatar
Okay, any specifics you would recommend?
Old 01-09-2014, 11:49 AM   #19
TorchRed6's Avatar
honestly couldnt tell ya, man. you'd just have to look around.
Old 01-09-2014, 11:53 AM   #20
Veracadoro's Avatar
Alright I appreciate all of the help
Old 01-09-2014, 11:57 AM   #21
TorchRed6's Avatar
no prob. good luck to ya
Old 01-09-2014, 12:36 PM   #22
03Graymach's Avatar
Torch is right with the slotted and drilled you loose stoping power due to less surface area and you will need and a new ECM if you really want to do it the people that said get a donor car they are right because you will need everything out of the engine bay pretty much as well as the suspension but at that point I would go aftermarket you will also need the tranny, the drive shaft and rearend once you get what you need from the donor car you can sell it and get some money back
03Graymach is offline   Reply With Quote
Old 01-10-2014, 09:35 AM   #23
bkh1994's Avatar
There is a turbo kit for the 3.8. They are on tmaturbo.com if you'd like to check them out. Just thought I'd throw that out there
bkh1994 is offline   Reply With Quote
Old 01-10-2014, 09:37 AM   #24
Veracadoro's Avatar
Thanks, I appreciate the info, I think I'm going to save up for a mach one and put the twin turbo I'm looking a into it. Rather than do a full swap on my car
Old 01-10-2014, 09:43 AM   #25
Veracadoro's Avatar
I'm having trouble finding anything that specifies any model or year information
Old 01-10-2014, 09:44 AM   #26
03Graymach's Avatar
Only problem with a mach is the high compression for a turbo set up but if you plan on building the motor you will have not problem
Old 01-10-2014, 09:46 AM   #27
Veracadoro's Avatar
Once I get the car I would be doing a full internal rebuild/upgrade.
Old 01-10-2014, 09:49 AM   #28
03Graymach's Avatar
Why not just by an 03 cobra and twin turbo it that way you don't have to worry about the aluminum block
Old 01-10-2014, 09:51 AM   #29
Veracadoro's Avatar
The main reason I'm stuck on the mach is just the look, I've wanted one for quite awhile.
Old 01-10-2014, 09:56 AM   #30
bkh1994's Avatar
They are custom kits. He builds for whatever car you've got. He has premade 99-04 v6 kits. The choices are the options for the car you ask him about.
You could always just make a mach clone
Old 01-10-2014, 09:58 AM   #31
Veracadoro's Avatar
I suppose I could
Old 01-10-2014, 10:08 AM   #32
03Graymach's Avatar
[QUOTbE=Veracadoro;1921516]I suppose I could[/QUOTE]
would be cheaper to buy a hood and shaker than all forged internal
Old 01-10-2014, 10:11 AM   #33
Veracadoro's Avatar
That is true but almost any car I get and work on like this would be getting reworked internals
Old 01-10-2014, 01:11 PM   #34
I was thinking the same thing and tax season is around the corner but seen this whole mach 1 conversion seems like it come with everything. A shop quoted me 1100 for the swap he told me I would spend more getting the parts than the install would cost, but the engine is 5000Click image for larger version
Name:	ImageUploadedByMustang Evolution1389384625.476373.jpg
ID:	144251Click image for larger version
Name:	ImageUploadedByMustang Evolution1389384641.183908.jpg
ID:	144252....btw don't go buying my motor lol
Old 01-10-2014, 02:21 PM   #35
Veracadoro's Avatar
lol I've got like 500 right now. I'm no where near buying that motor. Just trying to get a plan before I start spending....
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
Engine swap options? (2010 V6) Torch10 2011-2014 V6 Mustang 17 08-26-2013 07:38 AM
v6 swap to cobra will21 Pre-2005 V6 Mustang 43 09-07-2011 04:56 PM
4.6 swap write up please help sethhawk1 General Mustang Discussion 4 07-29-2011 11:39 AM
2000 3.8 ยป 4.6 swap mustang newb sethhawk1 Pre-2005 V6 Mustang 14 07-28-2011 10:41 PM
04:23 PM
