Spacer Install Q's - Mustang Evolution
Old 12-02-2003, 06:03 AM   #1
Send a message via Yahoo to 98GreenStallion
Spacer Install Q's
I was wondering if I need to buy the EGR valve adapter or could I just do without it? If I do have to have it, what exactly is it and where do I get it? Also, I still seem to be a littler confused on where this hidden tube is under my intake manifold?
I bought some phenolic material from Erik, I plan on cutting and making the spacer myself like he did.
thanks, Aaron
http://images.cardomain.com/member_i.../402003_35.jpg
Mods: BV heads, cut and weld upper, fully ported lower, 216/225 cam, 1.73 RR's, 60mm TB, 19# injectors, new timing set, 25% UDP, CAI, SCT chip, PCV delete, EGR delete, MAC LT headers, O/R H-pipe, durablack cat-back...
www.rpm-mustangs.com
RDmotorsport
New dyno
193.8rwhp/238.9 rwtq
98GreenStallion is offline   Reply With Quote
Old 12-02-2003, 06:38 AM   #2
Monkey's Avatar
you dont need the egr adaption plate.
to find the egr, just look for a big silver bowl type thing near your upper manifold. that is the egr.
Old 12-02-2003, 08:24 AM   #3
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
It's not a plate that he's talking about though. It's the tube extension that is mentioned in the how to. I was wondering about this as well. I will be installing my spacer one of these days (after I get the bolts) and was wondering what the size of this extension is (diameter and thread pitch)
thanx
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 12-02-2003, 09:09 AM   #4
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
The total length of the extention is about 2 inches... I'll see if I can find a picture...
You can see that it is standing on it's end on the left-middle side of this picture. I'm not too sure of the pitch angle at all... since I didnt take my calipers to it before I installed it. You could always email Flex and ask him the specs on it.
Weither or not you really NEED it is questionable... but your pipe manuvering/rebending skills will be put to the test. Even with the extention, I had to rebend the pipe a little to get it to work right.
Rellik is offline   Reply With Quote
Old 12-02-2003, 11:34 AM   #5
hmmmm, stick a tire iron in the end of the pipe and go to work on it?
-Adolf Hitler, 1935
3.73's and T-Lock among other Q's dusty97 Pre-2005 V6 Mustang 7 09-10-2008 02:53 PM
Just bought a 99 V6 5spd. Few Q's? Scorpion1 Pre-2005 V6 Mustang 6 06-25-2008 01:12 AM
New Exhaust Q's, need your A's Seph Pre-2005 V6 Mustang 10 01-26-2005 09:57 AM
Cam Q's for 00 4.6 2V Funky4.6VERT 1996-2004 Mustang GT 6 07-14-2004 10:32 AM
Newbie to AUTOX and a few Q's timpryor General Mustang Discussion 9 06-16-2004 01:20 PM
11:41 PM
