Radiator - Mustang Evolution
Old 01-20-2014, 02:30 PM   #1
Zinc's Avatar
Radiator
My car is running hot with 100% coolant in the radiator.
What should I do?????
Also what furs is for the cigarette lighter (I'm trying to charge my phone)?
Zinc is offline   Reply With Quote
Old 01-20-2014, 02:40 PM   #2
Adogg's Avatar
Check your thermostat, and your second question I don't understand what is furs?
Don't hate....... appreciate
Old 01-20-2014, 02:41 PM   #3
Zinc's Avatar
I ment fuse
Old 01-20-2014, 02:43 PM   #4
Zinc's Avatar
Thank you that it is the thermostat and what fuse do I need??
Old 01-20-2014, 02:48 PM   #5
Adogg's Avatar
It was the thermostat? And the fuse box should tell you which one I assume, or the manual.
Old 01-20-2014, 02:56 PM   #6
samuelsmith's Avatar
#1 top left corner
Old 01-20-2014, 02:58 PM   #7
Zinc's Avatar
15? Or 20?
Old 01-20-2014, 02:59 PM   #8
Adogg's Avatar
It's number 20 on my car
Old 01-20-2014, 03:39 PM   #9
Site Sponsor
Sponsor
AMWill's Avatar
Zinc,
You can't run 100% coolant in any car. It WILL overheat. You need to strive for a 50/50 mix of coolant and water. Either drain half the coolant out of the system and fill it up with water, or drain it all out and fill back up with a 50/50mix. Until you do one of these two options, the car will always over heat and possibly damage the engine.
Also, a little tech note- when a thermostat fails, it gets stuck open. Thermostat failures only result in cold engine temperatures. Never will it result in an overheating issue.
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Radiator support Contourdrew 1979-1995 Mustang GT 1 02-06-2012 05:03 PM
Radiator Bussinger 2005-2010 V6 Mustang 0 11-30-2011 05:48 PM
radiator swap Q mystang50 1979-1995 Mustang GT 18 11-19-2011 10:08 AM
Mishimoto Radiator / Dual 12" Install jk_aktion 1996-2004 Mustang GT 7 10-06-2011 08:19 AM
Radiator question? WhiteCobra94 1979-1995 Mustang GT 5 08-22-2011 10:14 AM
05:20 AM
