Possible alignment issue? - Mustang Evolution
Old 01-20-2014, 08:41 PM   #1
ahhhitsvito's Avatar
Okay, so this may be a dumb question, but I noticed today that the front tires aren't in the center of the wheel well. I don't have any problems while I'm driving or anything. Is this a possible alignment issue? Will it hurt if I keep driving the way it is?
ahhhitsvito is offline   Reply With Quote
Old 01-21-2014, 12:34 PM   #2
2000stanguy's Avatar
Can you post a pic to help us understand what you mean?
Performance Red 2000 v6- m112 supercharger,42lb green top injectors, 310lph fuel pump, BBK shorty headers, True dual exhaust, strut tower brace, GT rear sway bar, Steeda triax short throw shifter, SR lowering springs, tinted headlights and foglights, polk audio speakers, MTX subwoofer, Kenwood head unit and black leather interior.
2000stanguy is offline   Reply With Quote
Old 01-21-2014, 12:41 PM   #3
Yeah, I can when I get off work.
Old 01-21-2014, 02:59 PM   #4
samuelsmith's Avatar
Probably a hub bearing, just guessing. Your in luck, they do not need to be machine pressed on our cars.
Old 01-21-2014, 03:00 PM   #5
It's not spot on, but it should give you the same idea hopefully.
Name:	ImageUploadedByMustang Evolution1390341541.557598.jpg
Old 01-21-2014, 03:44 PM   #6
fwalck's Avatar
That's how all of mine have been I don't know why ford did it but that's how they all are.
fwalck is offline   Reply With Quote
Old 01-21-2014, 03:55 PM   #7
Jack the car up where the wheel is in the air. Pull and push, left and right, up and down. If the wheel and rim move it is your hub(wheel) bearing. It's hard to tell from a strait forward pic. if that is the problem.
Alignment after lowering robin_gt 1996-2004 Mustang GT 10 12-15-2013 10:33 AM
Issue with flywheel on an engine swap awwphooey 1996-2004 Mustang GT 10 10-15-2012 04:27 AM
5.0 Dying Issue bbecker 1979-1995 Mustang GT 2 01-04-2012 10:36 AM
EVAP issue plaguing Mustangs! fluffyGT06 General Mustang Discussion 2 12-01-2011 11:56 AM
gauge issue mrc 1996-2004 Mustang GT 3 09-13-2011 08:14 AM
02:39 PM
