Mustang won't start - Mustang Evolution
Old 01-27-2014, 01:23 PM   #1
kickerofdoom's Avatar
Mustang won't start
2001 v6 vert won't start has gas, battery is fine what else can I check can a timing chain go bad at once
Old 01-27-2014, 01:29 PM   #2
need more details. What happens when you turn the key
KraftDinner is offline   Reply With Quote
Old 01-27-2014, 01:34 PM   #3
Thrift light flashes and you hear the car trying but not starting
Old 01-27-2014, 01:37 PM   #4
tick tick tick?
or do you hear it turning over....
Old 01-27-2014, 01:41 PM   #5
Okay this may sound obvious but are you using the rite key?
Old 01-27-2014, 01:47 PM   #6
I hear it slow starts and yes I tried the other key I have and both don't work
Old 01-27-2014, 01:56 PM   #7
if you keep the key turned does it eventually just stop trying to start?... and you know the battery is fully charged?... have you done anything to your car since the last time you shut it off? even just washed it...
Old 01-27-2014, 02:25 PM   #8
Yes to your first question and I have charged the battery and just drove it.
Old 01-27-2014, 02:34 PM   #9
so it was tick tick tick. then you charged the battery and now the car works again?
Old 01-27-2014, 09:03 PM   #10
The car doesn't work still
Old 01-27-2014, 09:23 PM   #11
samuelsmith's Avatar
Try spraying some fuel injector cleaner in the throttle body and see if it will crank
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
97 Mustang won't start caulderk 1996-2004 Mustang GT 2 01-15-2012 06:11 PM
Good Information Thread. ESG642T Pre-2005 V6 Mustang 10 01-13-2012 08:00 AM
What parts should I start replacing on a '96 Mustang, Manual, with 200,000+ miles??? Mustang_Madness 1996-2004 Mustang GT 5 01-08-2012 09:45 PM
68 mustang no start Dexter Classic Mustangs 5 10-10-2011 11:26 AM
06:11 PM
