Nitrous Question - Mustang Evolution
Old 12-02-2003, 08:30 PM   #1
Send a message via AIM to 02whitestang
Nitrous Question
Alright I'm installing my nitrous set up on Thursday and I got a couple questions. First, I need to run autolites sparkplugs right and a heat range cooler and what should they be gapped at? Second, should I run 93 or 89 octane? Third, anything else that I should know so I can get everything ready cause Friday is the last day the track is open here and I want to have every thing ready.
Thanks.
02whitestang is offline   Reply With Quote
Old 12-02-2003, 08:37 PM   #2
tire's Avatar
Send a message via AIM to tire
if they are going to stay in the car while daily driving, go one stage colder. if you are going to have a set of spark plugs for the track then get two stages colder. i don't use nitrous on the streets so i just run stock plugs until at the track. they are kinda *****y to change on our cars (the 4.6l guys are lucky, they are easy on them) so do what you want. motorcraft copper AWSF-22C's are two stages colder and AWSF-32C's are one. -42C's are stock equivalent. i don't know the autolite equivalents but you can ask any chain auto store. gap bigger than .035-.038. don't go bigger than .045 though. run as high octane as you can, 91 or 93 depending where you live and what is available.
-austin
tire is offline   Reply With Quote
Old 12-03-2003, 12:40 AM   #3
Send a message via AIM to Talley
Did you know 4.2 F150's come with a "34" heat range factory.
Talley is offline   Reply With Quote
Old 12-03-2003, 04:26 AM   #4
RGR
Send a message via AIM to RGR
welcome talleywacker!
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 12-03-2003, 08:37 AM   #5
Monkey's Avatar
gap .035
Old 12-10-2003, 09:36 PM   #6
I'm in the middle of installing my kit and i have a couple of questions
when i went to install my window switch it had a wire that said to go to the negative side of the decive i was using it for, does that go to the switch or to the solenoid?
Old 12-11-2003, 07:46 AM   #7
this all looks foreign to my eyes
2000 Chevrolet Tahoe LS
5.3L VORTEC (not V-TEC) V8
4-Speed Automatic 4x4
Garaged:
1990 Ford Mustang GT
5.0L V8
4-Speed Automatic Overdrive
ItWouldAppearSo is offline   Reply With Quote
nitrous
nitrous question gambit90lx 1979-1995 Mustang GT 10 08-24-2007 07:59 AM
nitrous question? ryanxup Pre-2005 V6 Mustang 63 03-04-2007 06:19 PM
NItrous question BluStang6 Pre-2005 V6 Mustang 9 05-11-2004 08:39 PM
v6 nitrous question blk2kconvstang Pre-2005 V6 Mustang 8 03-02-2004 07:01 AM
Nitrous Question ponyboy1995 Pre-2005 V6 Mustang 5 10-13-2003 09:40 AM
04:03 AM
