Aftermaket torque converter? - Mustang Evolution
Old 01-28-2014, 05:05 PM   #1
2000v6stang's Avatar
Region: Iowa
Im looking at the TCI lockup torque converter on AM. I want to know is this something that I should put on a daily driver v6 with light mods? Also can someone explain what the RPM stall is? I think I have an idea what it does but just need someone to clear it up for me. The RPM stall on this TC is at 3000 RPM.
Blacking it out, MAC duel exhaust, SR CAI, Performance Automatic shift kit. And a long build list wrecked in July '14
2000v6stang is offline   Reply With Quote
Old 01-28-2014, 08:59 PM   #2
Blakhwk's Avatar
I read in many places that it's not good for daily drivers, you need to have powerful mods to add the high stall t/c, I'm also looking for a t/c but not sure yet what's the best aftermarket that is same as stock spec.
Visca Barça
Blakhwk is offline   Reply With Quote
Old 01-30-2014, 11:37 AM   #3
Region: Iowa
ok thank you let me know if you find something some thing and Ill keep looking
Old 01-31-2014, 01:27 PM   #4
davidcseifert's Avatar
Region: Arkansas
A 2500 stall would do decent with a stock motor, I have a 3K in my car and it does wonders. Daily driving, eh depends how you drive, as long as it still locks up in OD highway will be unaffected. Even with my 3K I can let off the brake when stopped and the car still tries to pull itself, under light throttle the car won't rev up higher to move, some think you have to get to the stall speed before it will do anything which is not the case. Once you do put your foot into it, WOT, the converter will flash up to the stall speed and then it starts biting and pulling.
blower/new cam soon
Old 02-03-2014, 11:48 AM   #5
Region: Iowa
So you think the 3K torque converter I want would be a good thing to put on my daily driver? I drive it a little harder than most so I want to make it faster
Old 02-03-2014, 11:57 AM   #6
Region: Arkansas
It might be a little much for a stock motor, mine is a heads/cam/intakes setup lol
blower/new cam soon
Old 02-07-2014, 07:34 AM   #7
sam62893's Avatar
^lol far from stock
Old 02-11-2014, 10:10 AM   #8
willb2305's Avatar
does circle d make a converter for your car? that will be the last converter you will ever need they are built to last. i hear ups and downs about TCI and that they start slipping after a year or two.
2012 V6
AirRaid CAI, BBK Ceramic LT Headers, BBK Catted X Pipe, Borla ATAK, MPT 93/97 Tune, Steeda LCA's and UCA, Steeda Relocation Brackets, 373 gears, WaveTrac LSD, Dynotech Driveshaft. Prothane Motor Mounts, Whiteline adjustable panhard bar & brace.Ground Control Coilovers with Koni's custom valved. Coming soon Circle D 3800 Stall and Lone Wolf Intake Manifold.
willb2305 is offline   Reply With Quote
Torque Converter WhiteCobra94 1979-1995 Mustang GT 4 12-28-2011 10:47 AM
Torque Converter ? WhiteCobra94 1979-1995 Mustang GT 6 12-07-2011 06:45 PM
Torque Converter Dbsaints 2011-2014 Mustang GT 3 09-29-2011 08:55 AM
torque converter question workmail21 1979-1995 Mustang GT 7 08-16-2011 08:15 PM
torque converter access plug? shustwit Pre-2005 V6 Mustang 0 07-03-2011 07:44 AM
09:48 AM
