Pinion - Mustang Evolution
Old 07-29-2008, 09:55 AM   #1
SC_STEEDA's Avatar
Pinion
What is the difference between a pinion and a t-loc?
SC_STEEDA is offline   Reply With Quote
Old 07-29-2008, 01:57 PM   #2
Send a message via AIM to tedness
Re: Pinion
pinion? i thought that referred to rack and pinion..i.e. front of the car.
whereas t-loc is a type of differential for the rear
or is there pinion elsewhere?
tedness is offline   Reply With Quote
Old 07-29-2008, 02:06 PM   #3
SC_STEEDA's Avatar
Re: Pinion
There is a pinion in the differential.
Old 07-29-2008, 02:08 PM   #4
Re: Pinion
The non technical explaination is...you have a pinion gear in your rear end that is separate from the t-loc. I'll let someone else do the technical definition.
Old 07-29-2008, 02:17 PM   #5
Re: Pinion
ring and pinion is in the rear-end, the pinon transfers power from the driveshaft to the ring gear that is bolted to the t-lock, they work together, one doesent work without the other.the t-lock just replaces the limited slip junk.
SimplyOrange is offline   Reply With Quote
Old 07-29-2008, 02:25 PM   #6
Re: Pinion
ring and pinion
8.8 t-lock
assembled, pinion is behind this driving the ring gear, pinion gear is the one that has the shaft on it.
let me know if i need to elaborate more, ill be back on tomorrow.
Old 07-29-2008, 04:42 PM   #7
SC_STEEDA's Avatar
Re: Pinion
ok thanks for the info!
rack & pinion 04TRV6 Pre-2005 V6 Mustang 11 03-08-2010 07:14 PM
Pinion Gear Shims V6Terry Pre-2005 V6 Mustang 1 10-10-2009 12:07 PM
Rack and pinion Scut95 The Bar 0 05-11-2008 06:54 PM
Rack and pinion Ponycarman Pre-2005 V6 Mustang 13 06-17-2005 06:27 PM
Got a pinion seal leak... SpectorV Pre-2005 V6 Mustang 18 01-04-2005 08:19 PM
09:14 PM
