Headers - Mustang Evolution
Old 01-29-2014, 11:24 AM   #1
keaton12's Avatar
Headers
I have a 00 v6 with dual divorced 2.5 pipes to dual flowmaster 40 mufflers, I am thinking about adding headers which headers would give me the best sound and hp gain
keaton12 is offline   Reply With Quote
Old 01-29-2014, 11:35 AM   #2
BamaStang93's Avatar
Best sound? Longtube headers. Better performance? I do not know . Word of caution, if your car is lowered, be careful if you're going with longtubes because they tend to hang lower and may scrape going over speed bumps
BamaStang93 is offline   Reply With Quote
Old 01-29-2014, 11:37 AM   #3
I do see that you are new to the site, so welcome! Also go check out YouTube for longtube and shorty header videos so you can decide which one sounds better to you. Also check out AmericanMuscle.com for some helpful exhaust tips!
Old 01-29-2014, 11:41 AM   #4
keaton12's Avatar
I was thinking either JBA cat4ward shorty headers or MAC long tube headers
Old 01-29-2014, 11:50 AM   #5
Do you have an aftermarket mid pipe?
I'm running a MAC catback with Mac shorty h-pipe/no cats and mac longtubes on my v6 and it sounds AMAZING
Old 01-29-2014, 01:28 PM   #6
Do the longtubes I got the same setup as you but I got longtubes and I think it sounds amazing
Codyty is online now   Reply With Quote
Old 01-29-2014, 02:29 PM   #7
keaton12's Avatar
I just bought the 2 flow master 40s and took it to the shop and they put divorced duals to the mufflers and used there own tips
Old 01-29-2014, 02:35 PM   #8
Same setup lol but yea I think longtubes with that you would love that
Old 01-29-2014, 03:56 PM   #9
keaton12's Avatar
Alright thanks
Old 01-29-2014, 04:02 PM   #10
keaton12's Avatar
There won't be a problem adding headers after the exhaust has already been done right?
Old 01-29-2014, 04:20 PM   #11
If I'm not mistaken if you hat cats they will have to come off I think and cut a little on your exhaust
Old 01-29-2014, 04:24 PM   #12
2000stanguy's Avatar
Longtube headers give the best performance and hp gains. If you don't have a shorty mid pipe you can't just add them unless an exhaust shop cuts the cats off and may need to add some pipe to make them fit.
Performance Red 2000 v6- m112 supercharger,42lb green top injectors, 310lph fuel pump, BBK shorty headers, True dual exhaust, strut tower brace, GT rear sway bar, Steeda triax short throw shifter, SR lowering springs, tinted headlights and foglights, polk audio speakers, MTX subwoofer, Kenwood head unit and black leather interior.
2000stanguy is offline   Reply With Quote
Old 01-29-2014, 04:31 PM   #13
keaton12's Avatar
Should I just get the long tube headers and take them to the shop?
Old 01-29-2014, 04:37 PM   #14
That's what I did but mine needed new gaskets
Old 01-29-2014, 04:42 PM   #15
keaton12's Avatar
How much did it cost you?
Old 01-29-2014, 08:09 PM   #16
Parts labor and everything I was about 1300-1400$ in on it
Old 01-30-2014, 08:15 AM   #17
black04v6's Avatar
I put pacesetter longtube headers on my car with a. Off-road h pipe midpipe. I have flow master catback. Sounds pretty good at low rpms once you get above 3500 however it'll get pretty high pitched. Longtube definitely better for performance tho. It'll never be a v8
black04v6 is offline   Reply With Quote
Old 01-30-2014, 10:53 AM   #18
keaton12's Avatar
I already have divorced duals though I just want to add headers
Old 01-30-2014, 11:05 AM   #19
Then shorties are the best way to go unless you really want longtubes, because it will cost a lot more.
Old 01-30-2014, 12:40 PM   #20
Old 01-30-2014, 04:47 PM   #21
keaton12's Avatar
Do they sound the same as longtubes?
Old 01-30-2014, 04:56 PM   #22
No, if your putting longtubes in you have to remove your cats. So if you you do shorties and leave the cats on it will be a lot quieter. Also longtubes will be deeper but shorties do give a bit deeper exhaust tone. I went with BBK ceramic coated shorty headers because I want them to last and keep my cats.
Old 01-30-2014, 05:20 PM   #23
2 Stangz's Avatar
Region: Nevada
I don't have any proof in-hand, but I've been told by complete gearheads in person that shorty headers really don't offer any gains, unless you get the ceramic ones, then maybe your engine temps will stay lower.
Old 01-30-2014, 05:36 PM   #24
samuelsmith's Avatar
You can relocate the 4 cats. But most people buy 2 shorty cats because you gain more hp. The original cats will have to be put in a pipe bender and welded. With the shorty cats you cut your pipe and clamp them on with the clams included. You can also weld.
If you take it to a exhaust shop the Federal Government requires them to make sure you still have cats.
But you could do it yourself.
Old 01-30-2014, 07:59 PM   #25
keaton12's Avatar
I would do it myself but to be honest I'm not real good with mechanics
Old 02-02-2014, 11:14 AM   #26
Depends where you live at what shop you take it too also mine took my cats off haha
Old 02-02-2014, 12:50 PM   #27
keaton12's Avatar
Did it sound good?
Old 02-02-2014, 03:06 PM   #28
Man it sounds amazing kind loud when idling but when you floor the gas it roars for a v6 I only had mine like that for 3 days before I sent it off to the custom shop so I can't wait to get it back
Old 02-03-2014, 10:21 AM   #29
keaton12's Avatar
What did you send it to the shop for this time?
Old 02-03-2014, 12:33 PM   #30
Mirrored black paint job custom sound unit and bodywork
Old 02-03-2014, 11:29 PM   #31
lemons95's Avatar
Longtubes have best performance and sound, won't pass a visual inspection though if your state does it. Short tubes came stock on 94-98's and don't usually crack. They look a lot cleaner than manifolds and give slightly better performance and sound.
Old 02-04-2014, 10:23 AM   #32
keaton12's Avatar
I just want long tubes for the sound and performance but I already have divorced duals
Old 02-05-2014, 09:28 AM   #33
Not to jack the thread, I took my car to the shop to get brakes done and the guy says it looks like I have headers. When I bought the car last summer dealer didn't tell me anything. Just wanna know did ford put some type of headers on our car. It's not chrome or anything. Will try to take pics later today
Old 02-05-2014, 09:36 AM   #34
Are these headers if so are they stock or factory
Old 02-05-2014, 09:54 AM   #35
bucko's Avatar
"Shories" verses "longtubes" can depend on the cubic inch size of the engine, and RPM range you want to produce (more) power in. Shorties work well with smaller displacement engines, such as the V6 in the midrange RPM band. Longtube works good in the upper RPM range for both small and bigger displacement engines. However, engines differ in this "theory", depending on intake and head characteristics.
The best way to know how well your engine will perform to which type (headers) is to gather as many dyno results with both, and compare to what modes (if any) you currently have.
Headers Wmcgrattan 2005-2010 V6 Mustang 0 11-30-2012 02:55 PM
ANYONE thinking about buying headers! 02NightmareGT 1996-2004 Mustang GT 36 04-05-2012 10:29 AM
Jba 1 5/8 shorty headers (insight on jba headers) go or no go? Swangin_Stangs 1979-1995 Mustang GT 24 01-13-2012 06:15 PM
Ordered headers today, but.....? WhiteCobra94 1979-1995 Mustang GT 2 01-02-2012 10:29 PM
headers Robbie94gt 1979-1995 Mustang GT 21 12-09-2011 07:59 PM
09:49 AM
