few questions on my build - Mustang Evolution
Old 01-29-2014, 06:32 PM   #1
jeMstang's Avatar
1) I have an 01 v6 with an swap to an 03 engine and there's a 94 5.0 being parted out, would the exhaust fit mine? just after the mufflers so I can have a dual exhaust going over the axel instead of having the exhaust coming out the side.
2) Could I also get the gears from that 94?
3) And split differential?
4) What other parts could I get from it to put on my v6?
jeMstang is offline   Reply With Quote
Old 01-29-2014, 08:42 PM   #2
2000stanguy's Avatar
Do you just have the engine and trans from the 2003?
Performance Red 2000 v6- m112 supercharger,42lb green top injectors, 310lph fuel pump, BBK shorty headers, True dual exhaust, strut tower brace, GT rear sway bar, Steeda triax short throw shifter, SR lowering springs, tinted headlights and foglights, polk audio speakers, MTX subwoofer, Kenwood head unit and black leather interior.
2000stanguy is offline   Reply With Quote
Old 01-30-2014, 08:15 AM   #3
jeMstang's Avatar
No, just the engine. I had to transfer the flywheel from the old engine to the new one because that was an auto and on the process I bought a new clutch for it so that I wouldn't have to replace it later.
Old 01-30-2014, 11:15 AM   #4
Then no, you can't use much off of the 1994 because the gears and differential are for an 8.8 rear end and your car is a 7.5. If you take the entire rear end out it will be 3" too short and you would also need wheel spacers and extended studs. Idk if the exhaust will fit, somebody else can help you with that. What other parts did you want?
Old 01-30-2014, 11:56 AM   #5
jeMstang's Avatar
that was pretty much all. thank you very much.
Old 01-30-2014, 11:57 AM   #6
jeMstang's Avatar
one more thing... which model could I get the gears and slip diff out of then?
thanks again.
Old 01-30-2014, 12:04 PM   #7
You need to buy a traction lock that fits the 7.5 rear end. Or you could buy a 99-04 GT rear end which is an 8.8 which is stronger and comes with traction lock.
Old 01-30-2014, 12:28 PM   #8
jeMstang's Avatar
could I get them from a donor car? and the rear end is the differential and gears both or just one?
sorry for my lack of intelligence on this part of the vehicle.
Old 01-30-2014, 01:51 PM   #9
Yes the gears sit in the differential and a traction lock came stock in the 1999-2004 GT. You will need the entire rear end. They can be found at salvage yards, if you find a rear end it will have 3.27 gears and while they are out you might want to have the gears changed. If you do buy a rear end buy all new oil and change the oil in the rear end.
Old 02-04-2014, 09:16 AM   #10
jeMstang's Avatar
I see. Ok well i'll go to the junkyard next weekend and see if I can find a gt. thanks bro, I appreciate it.
Old 02-07-2014, 08:25 AM   #11
sam62893's Avatar
Everything is spot on. You can make the exhaust fit. From the cats to the tips. Just have an exhaust shop weld them to your ride
Procharger questions FordLife93 2005-2010 Mustang GT 2 06-28-2013 10:06 AM
post deployment build Black99Snake SVT Mustang 12 03-06-2012 08:39 PM
Build Plan Questions 89Saleen141 1979-1995 Mustang GT 1 01-11-2012 07:01 AM
97 Mustang GT Build Brainstorming TheJigShow 1996-2004 Mustang GT 19 11-15-2011 04:34 PM
95 GT questions deadsp0t 1979-1995 Mustang GT 54 11-04-2011 03:16 PM
10:04 PM
