water temp spikes?? - Mustang Evolution
Old 01-31-2014, 06:28 PM   #1
TreyDeluxe's Avatar
water temp spikes??
1998 3.8. This is my first mustang so this may be normal but it just seems odd to me...when driving at normal speed my water temp stays in the "normal" section but every few minutes it will slowly creep up to the hot side. It gets all the way up and stays there for only about 5-10 seconds then rapidly goes back down to the mid section of normal. Is this a normal occurrence on mustangs? (The weather is cold...I live in Atlanta so Im sure you've seen what kind of weather Ive been dealing with, the radiator is full with anti-freeze)
Thanks
TreyDeluxe is offline   Reply With Quote
Old 01-31-2014, 06:42 PM   #2
samuelsmith's Avatar
Are you using the factory temp. sensor?
Old 01-31-2014, 07:01 PM   #3
not normal at all lol be careful you could destroy your engine if it hits the red line. If you car is over heating put your heat on full blast and it will help bring it down. but that's just temporary!.... I assume if your having poor weather you have your heat on... wonder what would happen if you turn your heat off how quickly she would go to hot
KraftDinner is offline   Reply With Quote
Old 02-01-2014, 03:09 AM   #4
TreyDeluxe's Avatar
I'm sure it's the factory sensor, I've never changed it but idk about previous owner and I actually played with the heater on the way to work today before I even read this but I didn't seem to notice any difference with heater on/off...I did notice today however the heater took alot longer than normal to start blowing hot air?
Old 02-01-2014, 03:18 AM   #5
change your thermostat and then go on with your day
Old 02-01-2014, 03:21 AM   #6
pretty simple. found you a video on how to
Old 02-01-2014, 04:03 AM   #7
TreyDeluxe's Avatar
ok ill get on that today but ive been doing some exploring on other sites and almost 100% of them say that i have air in my collant system (and i just added anti-freeze last week so im sure theres air in there) but out of all those sites not one gives me the steps or a good enough reference to flush/burp my system??
Old 02-01-2014, 04:11 AM   #8
just take the cap off and run your car itll bubble for a bit
Old 02-01-2014, 04:15 AM   #9
TreyDeluxe's Avatar
exactly what im looking for not the 8 paragraphs other people have been writing..thanks ill get on that after work and let you know how it goes.
Old 02-01-2014, 07:17 PM   #10
bkh1994's Avatar
I think it'd be the thermostat also
bkh1994 is offline   Reply With Quote
Old 02-02-2014, 07:09 AM   #11
TreyDeluxe's Avatar
bleed the system really well last night and filled it back up..ran like a dream this morning...temp nerver rose past the "R" in normal THANKS
Old 02-03-2014, 11:32 PM   #12
lemons95's Avatar
My temp sensor had a loose connection on the engine, I pinched it with pliers, put it back on and it worked fine.
Do Pulleys Give Horse Power 95 Mustang Gt Izon5.0 1979-1995 Mustang GT 23 05-13-2013 08:38 PM
Water Leak Kick Panel Area ThatsCoolBro 2005-2010 V6 Mustang 1 04-06-2013 11:20 PM
Water in the oil? lgw8471 1996-2004 Mustang GT 12 12-13-2012 06:47 PM
13' Hood vent water entry test Jetag93 2011-2014 Mustang GT 21 08-16-2012 08:58 AM
This is why you wax your car... illestdomer2005 2011-2014 V6 Mustang 26 06-11-2012 09:45 PM
12:57 AM
